changing a 4.2 to a 5.4sc 2001 f150
Old Feb 11, 2014 | 06:26 PM
bookie-1's Avatar
looking for advise...want to pull out 4.2 and tranny and install 5.4 sc and tranny....making the used or new pcm work with the truck and pats...
Old Feb 11, 2014 | 07:40 PM
Bilster's Avatar
This guy here has gone 4.6 to 5.4 SC. He may have some valuable resources. http://www.ford-trucks.com/forums/member.php?u=167960
I personally lost my 4.2 to hydrolock on two of my F150s. One I rebuilt stock and the other was a V8 swap. I'm no manufacturer brand lover so what I'm about to tell you may get you angry. I went to a GM 5.3/T56. The swap was easy. The conversion harnesses are readily available. I now have a ton of room under the hood. And....I gained 100 hp/100 ft over the 4.2 with mid 20 MPGs on the highway.
Old Feb 14, 2014 | 04:40 AM
AlfredB18's Avatar
Go for it then.
If you swap all the relevant computers and gauge cluster, you shouldn't even have to deal with PATS. Then again, I guess you'd still need keys synched to the PATS.
The rest is swapping stuff. Trans, driveshaft, axle, underhood stuff...chassis harness if you want to use the dual fuel pumps, etc.
Old Feb 14, 2014 | 05:50 AM
nonwoven29's Avatar
there's nothing wrong with lsx engines. Better rods then our 5.4 Oem. I've thought about it a time or 2 lol.
Old Feb 14, 2014 | 02:52 PM
jbrew's Avatar
Sell it.
Old Feb 19, 2014 | 09:32 PM
4x4dave's Avatar
Originally Posted by jbrew
Sell it.
lmao
Probably the best advice i've seen. 4.2 to a s/c 5.4 is a pretty serious undertaking.
Old Feb 19, 2014 | 09:36 PM
Roadie's Avatar
You would have to change out the rear also for the bigger one.
I agree with jbrew, sell it!
Old Feb 27, 2014 | 05:01 PM
1998f150xlt's Avatar
Coming from a guy who is about to swap in a 5.4 DOHC to his 4.6 truck, I would agree with the sell it suggestions. Unless you have a garage and buy an entire donor truck, don't even attempt a swap like this. Pat's is no big deal as it can be turned off in the tune and everything can be set up to work, but it's not for the faint of heart. If you don't have much mechanical experience don't even attempt it.
Old Feb 27, 2014 | 05:26 PM
azmidget91's Avatar
Yep, only way I would do it is to buy a donor truck and swap everything. There is always more than you think that needs to be swapped, and if you get an entire truck you know you have everything.
