98 F150 help!! with autopage keyless entry lock/unlock
Old Jan 17, 2014 | 04:35 PM
jasenford89's Avatar
I recently purchased an autopage c3-rs915 remote start/keyless entry alarm. I figured I can do everything myself and save the money and it will give me something to do. I have got the remote start function worked out (easy). But the door locking and unlocking system I can't figure out for the life of me. The truck had a code alarm on it when I bought it but eventually I had to rip it out because it started to melt the fuses. I'm not to sure if it came with a factory alarm or not.
My problem is I can get the locks to lock with te keyless remote but I cannot get them to unlock with it. They lock/unlock with the master switch. I understand that it is reverse polarity and I have wired the new alarm to the old relay setup the code alarm had. And from what I've seen on the12volt.com site, everything is correctly wired as far with the relays.
The factory unlock wire is pink/light
The factory lock wire is pink/yellow
Please correct me if I am wrong
Here is a link to how my relay wiring looks
viewtopic.php?f=6&t=10038" onclick="window.open(this.href);return false;
I did notice that my Lock and Unlock wire from the Alarm harness are switched. The Lock is going to the Unlock relay and the Unlock is going to the Lock Relay.
If you have any suggestions please let me know, I am going crazy over this. If I left anything out let me know
Thank you
Old Jan 17, 2014 | 11:06 PM
Sorry, that's not a link. What are you trying to post?
Old Jan 18, 2014 | 11:34 AM
http://www.bulldogsecurity.com/diagrams/778%20RELAY%20for%20TYPE%20C%20DOOR%20LOCKS%20DIAG RAMJPG.jpg
Old Jan 18, 2014 | 11:37 AM
http://www.bulldogsecurity.com/diagr...DIAGRAMJPG.jpg
Old Jan 18, 2014 | 11:40 AM
Oops
Old Jan 21, 2014 | 12:43 PM
dapert's Avatar
I have a different system than yours but mine is wired exactly like your diagram and I can't get mine to work at all either.
Not sure if I have the correct side of the cut wires on terminals 87a and 30 but I've tried it both ways with no luck. One way the power wire at the battery starts sparking and getting super hot. If I switch the connections on 87a and 30 I get nothing.
I found the pink/yellow and pink/green in both kick panels but no way was there enough room for me to work.
I popped that panel off the top of the dash oand found the same wires up there and super easy to get to.
Not sure what else to try so would love to see if anybody has answers.
