rough idle at first start...30 seconds maybe
Old Mar 18, 2010 | 10:44 PM
fordracing200's Avatar
I've got a 00 5.4 lariat 4x4 with 150k miles....the other day when i started it after it had sat all night it idled rough for about 10 seconds, like it was missing and it just did it again today after it sat at work for 8.5 hours.......went away after about a minute...why would this be? I haven't changed the fuel filter in the 6 months I've had it....maybe thats bad? dirty throttle body? only time it does it is when u first start it, and its hit or miss, but then again its only happened twice....? any suggestions? no check engine light..
Old Mar 19, 2010 | 08:07 AM
Maybe to both. It could be a sticky IAC or leaky fuel injectors.
Old Mar 19, 2010 | 08:50 AM
but it doesn't do it everytime it sicks for a few hours or overnight, just sometimes.....wheres the IAC, for some reason I am drawing a blank.
Old Mar 20, 2010 | 02:04 PM
Idle air controller.
Old Mar 20, 2010 | 02:25 PM
Toyz's Avatar
Located on the back of the throttle body, 1 clip, 1 hose, 2 8mm bolts. Remove and spray with intake cleaner.
Old Mar 22, 2010 | 08:55 AM
can I use carb cleaner or no?
Old Mar 22, 2010 | 10:21 AM
The best stuff to use to clean out an IAC is Seafoam Deep Creep.
Old Mar 23, 2010 | 06:12 PM
alright, think my local napa would stock that?
Old Mar 23, 2010 | 06:15 PM
f150fella08's Avatar
^ they should, they have it at walmarts too
Old Mar 23, 2010 | 09:37 PM
I dumped some $1.50 injector cleaner in it from family dollar no joke and it started to do it but 85% better then before, then almost immidiatly smoothed out and hasn't done it since...
Old Mar 23, 2010 | 10:13 PM
have you cleaned MAF and throttle body yet?? give that a shot..
Old Mar 24, 2010 | 10:32 AM
2low2go's Avatar
got the same problem, i have cleaned the IAC... i also cleaned the throttle body... still bad idle when starting on a cold start... gonna clean the maf tonight and see if that takes care of it...
Old Mar 25, 2010 | 02:25 AM
Bluegrass's Avatar
How the motor and computer handles cold starts;
When the ignition switch goes through the RUN position, the computer looks at the coolant temperature sensor value to make a decision on how much extra fuel to use and to opens the IAC for extra air and high idle and even a change in ignition timing.
As the motor runs in the first approx minute, the OX sensors heat enough to begin to take control of fuel and the high idle begins to come down as the temperature rises.
Look at the posibility of a faulty temp sensor, sticky IAC first.
Adding fuel cleaner to the gas takes awhile to be effective if there is clogged injectors.
Note that if the IAC is sticky, it is usually nearly closed when the hot motor was last shut down so is stuck in the closed position after cooling down.
Starting a cold motor now can't get enough air unless the throttle is stepped on to give it more air.
As the motor heats, the IAC may work again until the next time.
On an elderly motor it pays to go over everything and head off issues before they happen.
It's called maintainece!
Old Apr 24, 2010 | 04:30 PM
orr...trade it for a GMC....
