DDM HID here...is this everything? Plus questions
Old Apr 24, 2010 | 01:22 AM
SocalPike's Avatar
Hi all-
My HID kits finally arrived from DDM (about 3 weeks after ordering). I placed an order for the 9007 Hi/Lo and the H10 fogs. Everything on the left are for hi/lo and on the right are for the fogs. Is everything I need here? Or am I supposed to order anything additional?
What exactly is in the center? Is that for the 9007 setup?
Lastly in terms of installing my fogs, are they supposed to connect to battery?
Any tips would be appreciated.
[IMG][/IMG]
Old Apr 24, 2010 | 03:56 AM
Yogi.kudos's Avatar
The center one looks like that harness for the hi/lo kit.
I used a harness for my fogs, but other say that they plug right into the OEM connectors.
Old Apr 24, 2010 | 11:35 AM
dirtyd88's Avatar
That's everything man. The big wiring harness in the center is your hi/lo controller for the 9007 bi-xenon kit.
If you have any questions, feel free to send me a PM. I will try to get bak with you later this after as I will be out of the house for a bit.
I can help you with any install questions you have.
Old Apr 24, 2010 | 04:58 PM
SocalPike's Avatar
Thanks Dirty I appreciate it!
Few questions on the fog install ...
1) do the fog ballasts just connect to factory harnesses? I assume it does not need to be connected to the battery itself (can't see how with the short wiring)...just wanted to double check.
2) what are the two wires on the H10s (red and black) that end in a prong (for lack of a better word...I'm an electrical newbie)
3) I was looking at the install instructions from DDM and they mention to cut some of the wires out. However the pics in the instructions don't look the same as the ones I have in my picture. Did you have to cut any wires?
Thanks again!
