New guy with a cruise control problem
Hi guys. I need some direction. I'm pretty new to Fords. I just purchased a 98 F150 Lariat 3 door with the 4.6 and 5 speed stick. So far I like the truck.
The cruise control does not work. I've searched the forum for clues and found some information but it's been no help so far. So, here goes.
It seems the recall has been done since there is a fused wiring harness from what I presume is the SCDS and the fuse is good. All other fuses in the system are in good order.
I did find the instructions and tried to run the cruise control self test and here's the problem to this point. I don't see a cruise control indicator light and the owners manual does not show it's location so trying to run the self test just doesn't work.
Where in the world is that cruise control indicator light/lamp located?
common sense for me says the CC indicator light is the one on the cluster that lights up when you engage cruise?
other than that, no idea. try posting in the elec. forum, you'll get better responses there
If it came on during the pre start self test, as do the other lights one would normally find at that time, or it it showed in the owners manual I wouldn't have the need to ask it's location.
I will go ahead with a cross post though as well.
the cruise light on my dads 99 superduty is burnt out and cruise still works.
See if you got power to the servo box under the hood. If you have power to the servo box then try swapping out the box with one from the junk yard.
As to the swap out, I'm not much for throwing parts at a problem and would rather do the necessary diagnostics.
Before you tear the dash apart I'd just like to mention that my 1999 does not have a cruise indicator light.
I can't believe Ford would decontent something like that from 1998 so what you are looking for does not exist.
Also since you are new to Ford's, a Lariat with a stick is very, very rare. Only '97 and '98 was it even possible and the top trim line almost always had an Auto.
There are some instrument panel lights out and I'll be pulling it apart to replace the bulbs anyway so it will be a great time to double check on the cruise indicator light. The lack of one on your '99 fits right in with why I cannot find any sign of a light being there on my '98.
I have owned Fords in the past and managed a couple of fleets that ran Ford autos & light trucks, though not recently.
Have you downloaded the owner's manual and looked in it yet?
http://www.fleet.ford.com/maintenanc...ls/default.asp
Available back to 1996.
