spark plugs
Old Mar 23, 2010 | 02:21 PM
dcm522's Avatar
spark plugs
Does anyone know how to get the back two spark plugs out of a 99 f150 5.4l. i cannot even get my hand back there to get the coil pack removed, not to mention a wrench. thanks
Old Mar 23, 2010 | 05:39 PM
Raptor05121's Avatar
I break them loose from under the truck, but this is speaking from a V6
Old Mar 23, 2010 | 05:42 PM
f150fella08's Avatar
did you take the fuel rails off?
Old Mar 23, 2010 | 05:43 PM
Originally Posted by f150fella08
go under truck, reach up and you have a somewhat better angle of attack on the heads rather than looking down from the top of the engine
Old Mar 23, 2010 | 05:44 PM
not on a 5.4........
Old Mar 23, 2010 | 06:18 PM
illness95's Avatar
from what i gather you take everything off thats in the way.. no fanagling around things..
Old Mar 23, 2010 | 06:20 PM
on a 4.6 you can do them without taking off the fuel rails.
Old Mar 23, 2010 | 06:26 PM
illness95's Avatar
correct, but this is a 5.4 hes talking about
Old Mar 23, 2010 | 09:46 PM
fordracing200's Avatar
ahahah, just leave them......I'm not gonna bother with mine, what a joke. I don't know what ford was thinking with this motor...
Old Mar 23, 2010 | 10:09 PM
i know, i read that..i was just sayin
they are time consuming...but def worth a change every 60k or so
Old Mar 23, 2010 | 11:15 PM
Toyz's Avatar
You can reach them. On the passenger side zip tie the heater hoses out of the way. Unplug the cop...I found it best to use a small ratchet and deap socket with a 3" extension for the cop bolt (no wobbly, to much of a fight) Then take a 6" extension and your plug socket (no wobbly)(I tape the socket to the extension) reach back and drop it in the hole, then reach back with the right ratchet (try not to use one with the switch on top the head of the ratchet) and break the plug loose. Then remove the ratchet and back it out by hand turning the extension.
On the drivers side, disconnect the hoses necessary and do the same thing.
Sometimes it helps to just disconnect the rear bolts on the fuel rail so it can flex a little bit.
Old Mar 24, 2010 | 01:11 AM
CD1's Avatar
CD1
If it's anything like the 2001 5.4 then it'll take extensions and swivels to get it. I had more crap hanging off the damn ratchet than I thought was possible. It was a real pain in the **** but it's do-able.
Old Mar 24, 2010 | 10:31 AM
coobies5's Avatar
on my 4.6, i just removed the fuel rail and i could get to the plugs just fine. only had to remove the driver side fuel rail for it, passenger side i didnt have to do much to get to it.
Old Mar 24, 2010 | 11:34 AM
yea 4.6's are easy...i didnt have to remove anything except maybe a vaccum hose..cant really remember..
but the 5.4 is a whole different story
Old Mar 24, 2010 | 12:22 PM
Outlaws03's Avatar
I just completed a complete tune up on my 02 F-150. Number 4 and number 8 were a pain in the butt to get too. The problem was the fuel rail. Because I did not want to mess with taking it off, I just battled with it. Take your timke and be patient with it. It is time consuming, but you can get to all of the plugs without taking the fuel rail.
The other one that was a pain was number seven There is a **** that comes off the fuel rail that sit right over top of the coil pack.
Either way take your time, because it is frustrating. You will also learn new ways to twist your hands and arms around that you never knew you could do before. Good Luck
