intake manifold spacer
Old Apr 2, 2010 | 03:53 PM
2low2go's Avatar
okay, so i broke a bolt in my intake manifold elbow or as ford calls it "spacer"... its the upper piece that the EGR and IAC bolt to and also has the PCV line running in the back of it, the piece the throttle body bolts to, etc... etc... i had to drill and tap it to get the bolt out but as of right now it isn't leaking... but i would like to find another one so i can have it when it does go to leaking... i know it will... does anyone know if they are the same from the 4.6L to the 5.4L and what years are the same? thanks for the help!
Old Apr 2, 2010 | 04:07 PM
Veteran: Army
'97-'03 should be the same...
