new dude with a few questions...
Old Mar 24, 2010 | 11:42 AM
2low2go's Avatar
hello all!
well i'm new to the forum... i own a 2005 Mustang GT drag/street car and a 1997 4.6L/auto F-150 2WD extended cab step side with 193,000 miles on it... i got the truck when i was 15 and i'm now 26 so i have had it for a while... i am currently driving the car everday but it is to the point that i need to get something else to drive... i figured i would drive my truck instead of buying another vehicle...
now to the questions... when i parked the truck about 5 years ago it was getting around 20 MPG... i did the basic tune up of plugs, wires, air filter, fuel filter, and cleaned the throttle body... for some reason now it is getting the best of 15 MPG... i am looking for ways to get the best MPG i can... anyone got any suggestions... i have searched but would like to know your direct thoughts on what could cause it to drop so badly...
Old Mar 24, 2010 | 11:46 AM
f150fella08's Avatar
welcome new guy!!
may try some injector cleaner IE techron or seafoam in the gas tank.
what about a new PCV?? clean the IAC for S&G's
sure the converters arent bad?
Old Mar 24, 2010 | 11:56 AM
2low2go's Avatar
Originally Posted by f150fella08
welcome new guy!!
i cleaned the IAC when i cleaned the throttle body, should have wrote that... my bad (updated)... it prolly does need a new PCV... i haven't ever put one on the truck and it has 193,000 miles on it ... i put some injector cleaner in when i changed the plugs and run it out... just a STP gas/injector treatment cleaner... the converter's are prolly not in the best of shape but it nots putting off an odor or any excessive water out the exhaust... i think they are okay...
Old Mar 24, 2010 | 11:59 AM
2low2go's Avatar
i'm also open to any ideas on how to improve gas mileage... i'm thinking electric fans and underdrive pullies and replacing the 02 sensors but open to anything...
Old Mar 24, 2010 | 12:04 PM
def needs a new PCV and front oxygen sensors..the rears dont really do anything to affect fuel economy
Old Mar 24, 2010 | 12:53 PM
Hodum0430's Avatar
My 02
Hey man, I'm new here to.
Anyways I have a 2002 F150. It has 238,XXX miles on it and I'm barely getting 16 or 17 and I'm babying it EVERYWHERE. I have a CAI, cat back exhaust, and a TBS. Performance wise. I've cleaned every possible crack of the engine when it hit 225,xxx miles. I just figured its getting old, haha.
I did notice a difference in idle after i ran some engine restore when i last did my oil change. Try that and see if it helps.
Old Mar 24, 2010 | 12:54 PM
Hodum0430's Avatar
oh, and an electric fan...it didn't do anything since I have a Plastic belt driven fan already.
Old Mar 24, 2010 | 01:23 PM
what motor? extended cab? 4x4? 16 or 17 is pretty good on a motor with those miles...i get 16.7 everytime in my 02 4.6 extenede cab 2wd
i think your suppose to take the belt driven fan off...and wire in the e-fans.......
Old Mar 24, 2010 | 03:36 PM
2low2go's Avatar
you gain MPG from taking the clutched fan off and adding the electric fans... reduceses drag on the motor and frees up hp and torque...
Old Mar 24, 2010 | 03:44 PM
and UD pulleys MAY help as well...but i havent heard of that helping
Old Mar 24, 2010 | 04:00 PM
shifty_85's Avatar
what about you o2's? when were they last replaced? i know i was getting 15-16MPG then i did longtubes and replaced the front o2's and got 18-20 depending.
Old Mar 24, 2010 | 04:58 PM
2low2go's Avatar
um, yeah... last time them O2's got replaced...
i haven't replaced them yet... they are still the factory ones from 1997... i know, i know... i have never been concerned with gas mileage until now... i drive 60 miles a day round trip now... and always been into drag racing and those parts don't help gas mileage usually... lol...
i know i need the front O2's... should i replace the back to or just put some MIL eliminators in?
Old Mar 24, 2010 | 05:25 PM
coobies5's Avatar
custom tunes for increased mpg and some extra oomph when needed, along with a cai
Old Mar 24, 2010 | 05:42 PM
2low2go's Avatar
i have wondered about a tune... it will have to pull my car every now and then... when the car breaks and going to the dyno... which my dyno is in Florida... so it will have to make the trip... i need a tuner and a tune... i have an SCT XCal X3 in my mustang and really like it but a X2 would work fine for what i need... who is a good tuner? do they email you the tune?
Old Mar 24, 2010 | 07:07 PM
coobies5's Avatar
just get the strategy code from your truck and you can just upload the tunes to your x3
at least thats how i had to do mine when i had mine done. i have vmp tunes, but theres also troyer and powerhungryperformance, theres probably others, but those are most commonly used via mail tunes.
