torsion bars cranked and front end very low!!
Old Oct 4, 2013 | 08:31 PM
tfast150's Avatar
So I just did a trans swap to a 4r100 and used a parts truck for everything, now that I have it running the torsion bars are cranked all the way and the truck is sitting lower then stock! is there a right and wrong way they get installed? backwards, upside down or something!?
Old Oct 4, 2013 | 09:20 PM
4x4wolf's Avatar
Is your truck a supercrew, they typically don't level out when the torsions are cranked all the way.
Old Oct 4, 2013 | 09:52 PM
tfast150's Avatar
It is but with 7700 bars and cranked it shouldn't be lower than stock height.
Old Oct 4, 2013 | 10:28 PM
4x4wolf's Avatar
Are the bars old, they will wear out over time.
Old Oct 4, 2013 | 10:44 PM
tfast150's Avatar
Only 200,000 kms the ones that came out had twice as much and were twice as high!
Old Oct 5, 2013 | 12:58 AM
coobies5's Avatar
you have it "screwed in" right?
not "screwed out", correct?
Old Oct 5, 2013 | 11:41 AM
tfast150's Avatar
Correct! Hence why I'm so confused! Just so everyone knows this isn't my first rodeo, I've been on this forum for many years and have had multiple 97-03 trucks. Thanx in advance!
Old Oct 5, 2013 | 12:14 PM
coobies5's Avatar
that is strange, hope you get it figured out bud
Old Oct 5, 2013 | 01:12 PM
tfast150's Avatar
Thanx coobies! I'm thinking of just doing the lift keys but idont want them to snap inset too much load!
Old Oct 5, 2013 | 03:34 PM
Galaxy's Avatar
As you are aware, they are indexed. Maybe the ones you swapped in are indexed differently from the stockers you took out. Can you rotate them to the next hex and see if that works or does that then take it too far??
Old Oct 5, 2013 | 03:35 PM
Galaxy's Avatar
He could have 2,000,000 km's on them and this wouldn't happen…they don't wear/sag that much.
Old Oct 5, 2013 | 09:00 PM
JMC's Avatar
JMC
25 Year Member
Did you cross them side to side?
Old Oct 6, 2013 | 12:06 AM
tfast150's Avatar
There is a left and right side!!! They are marked with an L=drivers and an R=passengers and those marks also go to the crossmember end not the a-arms! Thanx for your help guys!
