ABS Pump Running 03 4.6 4x4
Hello, I've been trying to fix my ABS problem for some time now. I brought it to the ford dealer to get it diagnosed, and they told me the ABS module was the problem. They actually gave me the same codes I got from Auto Zone. Anyways, I bought a brand new abs module, installed it and I'm having the same problem. The pump will run as soon as I put the fuse in.
I'm wondering if there are relays I should be looking for? I need to to find out what is telling it to run.
C1185 - ABS power relay output Circuit Failure
C1096 - Pump Motor open circuit
50 Amp Fuse under the hood, location is upper right hand corner if your standing beside the truck. Not near it right now or I'd know the exact number.
I replaced the module part # YL3Z*2C219*B
First thing I would do is gently pull the abs sensors out and clean them really good. Be carefull not to break them there not cheap. Mine was having similar issues then after I cleaned the sensors off havent had one hiccup.
When I brought it to the dealer, I gave them the fuse and asked them to run the codes with the fuse in. If they actually did is anybody's guess though. I should probably have it checked at Autozone and bring the the fuse along and see what they pick up.
I replaced the rear sensor on the pumpkin, and checked the front sensors, they were pretty clean, and the resistance measured good. Wiring and connectors to the sensors looked good.
