won't crank
Old Oct 31, 2013 | 12:57 AM
Tmoore's Avatar
won't crank
2003 f150 4.6l triton v8. was going down highway and truck just dies. tried to restart it and it won't crank or turn over is does nothing. we just changed coil packs over the weekend..help please..this is our only vehicle
Old Oct 31, 2013 | 07:00 AM
projectSHO89's Avatar
Is your battery dead? That often happens when the alternator fails and the battery then runs down until everything just dies due to lack of power.
Old Oct 31, 2013 | 07:49 PM
papa tiger's Avatar
UR need for more than a jump. Battery cable, battery, alternator?
Old Nov 11, 2013 | 07:44 PM
THA_FOXXX's Avatar
tps sensor
Old Nov 11, 2013 | 09:37 PM
FunSocalTiger's Avatar
Take your battery in to get tested. If the battery is drained then the problem is most likely the alternator since it died while you were moving.
If that is not it, it could be your fuel pump too. That was the first thing that went on my 01.
Old Nov 11, 2013 | 09:43 PM
Bluegrass's Avatar
How do some of you think TPS and fuel pump when the starter won't turn the motor over as stated (called no crank)?
Good luck.
Old Nov 12, 2013 | 08:18 AM
The OP posted once two weeks ago and then never returned to the site. You can be sure that she still isn't stuck on the side of the road.
Let it go dormant, boys...
