Need info from a dash cluster
I was fixing another cold solder joint on my 03 & I screwed up & bridged two traces on the PC board. I poofed the surface mount voltage regulator on the board. It's along the bottom of the board marked Q16 but I can't read all of the markings on the component since the POOF. If someone out there has access to theirs & can read those markings on Q16 I would be so great full! I can solder a new on no problem just don't know which one to get. Again, any help is appreciated!!!!!!
here's some links to the cluster "how to's"
maybe the pics in them will help you out....
https://www.f150online.com/forums/ar...er-repair.html
https://www.f150online.com/forums/ar...ml#post4705018
https://www.f150online.com/forums/ar...r-97-03-a.html
