instrument cluster problem
I've come across a problem that I can't solve and hope someone here can help me out. Yes I've searched the web and this site but haven't found anything similar.
The Problem:
I have a '02 Supercrew 5.4 and half of the gauges don't want to work. The left side gauges work Fuel level, Oil Pressure and Speedo. The right side gauges that don't work are Tach, Volt Meter and Engine Temp. I've checked all the fuses and they're all good. I've disconnected the battery to try and reset the system and still no luck. I noticed this problem after I was trying to locate and misfire on the passenger side of the engine. All I did was doing disconnecting COPs and Fuel Injectors. I've gone back and made sure all the connections are sold even connections that I didn't mess with. Thanks in advance.
The Problem:
