wind noise from driver rear supercrew window
Well ever since i had the truck ive had this rather annoying wind noise coming from the rear crew cab window on the drivers side and finally getting around to investigation. I thought i read on here that this is a common issue and could be fixed either by buying a whole new window seat? sasch? track? if you will or throwing a bead of silicone inside where it mounts to the actual door frame. anyone have this issue that they have fixed before that can point me in the right direction?
