Problem while replacing radiator
As you likely found the tank fitting performs a seal between the tank and the cooler coil.
The line fitting is special in that it and the line is configured to use an O ring seal inside the fitting not a taper seal or compression.
Take the tank top holders off and rise the tank a bit to get at the lower fitting.
There are special wrenches with open slot ends for working on tube fittings.
Good luck.
Good luck.
