Swapping Rear Axle
Old Aug 1, 2013 | 08:04 PM
Chris Cook's Avatar
Swapping Rear Axle
I currently have a 3 55 88 XXXX and want to swap it with a rear axle that has a diff stamp of 3L55 88 XXXX.
I'm thinking this should be an easy swap, has anybody ever done this?
Old Aug 1, 2013 | 08:11 PM
02FORD4X4's Avatar
its a non limited slip to limited slip correct?
Old Aug 1, 2013 | 09:26 PM
Are you swapping the whole rear axle assembly or just the center section?
Old Aug 1, 2013 | 11:39 PM
illness95's Avatar
I swapped the entire axle in my ol 98.. Got rid of those god awfull drums brakes in favor of the disc brake axle ..
Old Aug 2, 2013 | 03:47 PM
EndZero's Avatar
I've been wanting to do the same. Have the same axle (3.55 gears, 8.8) and want limited slip. I heard it's easy if it's the same axle with the same gears just with an L between the 3 and 55. Also told I have make sure it will work with my brake system cause I have 4 wheel ABS. Gotta do more research.
Vehicles without limited slip being advertised as 2 wheel drive is an outrage.
Old Aug 2, 2013 | 05:23 PM
Galaxy's Avatar
Since you're going through all this trouble, see if you can find an axle with 3.73's!!!!
Old Aug 5, 2013 | 11:09 AM
Chris Cook's Avatar
Yea, It's not limited slip to limited slip, I want to change out the whole axle so I don't have to mess around with the diff.
I don't want to get 3.73 because the front axle still would have a 3.55 ratio.
I also don't think my truck comes with ABS, because the brakes sure as hell lock up. lol
Old Aug 5, 2013 | 12:16 PM
You have at least rear ABS, 4 wheel ABS was an option in 99 I believe.
