- Real bad idle
- overheating
- Brake Booster hose???
- valve rattle upon acceleration
- Help, truck runs like crap!!!
- Anyone add AC to non AC truck?
- Tune up?
- PVAC valve.
- Engine shopping, How to tell 5.4 from 4.6?
- swapped engine now runs worse
- High-pitched noise when hot from alt.
- Extremely loud rattling noise under the hood around 2k RPM's????
- Weird idle
- Emissions P0453 code
- Gas milage
- 91 F-150 Problems
- '00 5.4 Engine dies after start/P1409 code
- Concerns about manifolds
- service engine light
- 5.0 and 50hp shot of NOS?
- 03 Doesnt always start
- 97 f150 engine swap
- Track times and mods you got
- oil pump question
- 03' SuperCrew 4.6L engine oil
- possible remedy for initial piston slap?
- Intermittent Service Engine Light
- Oil Loss / Smell of oil
- 97 F150 engine wont start
- Air Box Mod/ My experience
- 97 exhaust manifold
- E-fan Screw Up - found and fixed
- sounds like a belt but no belt is on
- 02 f-150 4.2 slow overheat
- 4.6 - Ignition Coils
- Wierd stuff happening at higher RPM and locking doors
- 04 5.4 metal on metal sound during startup
- What computor
- New member needs EEC 4 diagnostic help
- #4 (Right rear)spark plug trick??
- #1 Cyl spark plug deformation
- Cubic Inch Displacement
- bad 02 sensors but no codes?
- 4.2 Swap
- What maintenance to do next??????? (75,000miles!!!)
- Air Force One Intake
- want to change a 4.2 to a 302
- More starter issues, new information
- rough idle with a/c on help please
- EVR and PFE questions
- New Airintake and Check engine light on...
- narrowing this thing down
- 04 5.4 300h.p.???
- Idle Speed
- Air Pipe Dilemma
- Changing a 4.2 to a 3.8, can it be done?
- 5.4 Driver Side Anti-freeze Leak
- 2000 4.6 starts then dies
- what brand of spark plugs?
- Oil Leak in my 4.9L
- Bad EGR valve?
- engine swap 95 to 98..... will it work
- 82 straight 6, 4.9 litre hard to start
- How do you get in touch with Ford?
- 1985 F150 TPS Code 63
- Acronym glossary
- Oil change
- oil in air tube.....help
- can the PO402 code for the egr valve
- Safe to use WD-40 on IAC?
- engine bog when cold
- 86 f150 distributor short
- Royal Purple motor oil
- Starting Problem 03 Screw
- Need help Again!
- My '98 4.6L Doesn't Have a PCV Valve
- 1994 F-150 XLT 5.0 V8 302 O2 Sensor(s)
- Explorer starter not engaging
- Looking For A Part Number...
- oil filter change
- PO401 trouble
- Mpg??
- 5.4 strange water leak
- Question No One Wants To Answer....
- Bad fuel injector cooler?
- Flex-a-lite E-fan warning
- 2001 5.4 Supercrew idle problems
- Truck engine went KER-PLUNK!!! This morning, what could it be?
- 1997 4.6 fubared?? (LONG)
- Idle help, searched already.
- Better mpg on non-reformulated gas
- cold air kit
- 2003 Won't Start, intermittant
- mustang block
- engine size for 1997 V-8
- ebay air intake???
- dead at 85,000
- 4.6 l engine diagram
- New member, New Truck
- turbo for 2000 transit locked up
- TPS or coil
- 1997 f-150-4.2
- 4.9L low oil pressure, blowby
- When driving my 99 5.4 on #75 it buck's and then stalls out
- serious problem...need help
- p0304
- Check Engine Light
- Truck wont start-PLEASE help
- clutch pedal assembly removal
- Antifreeze leaking after two fixes
- F-150 Diesel...Will it happen
- coolant temp sensor?
- I am New be nice
- '86 F150 revs and stalls at idle, please help!
- Texas Highway Patrol F-150's
- Why does my A/C blow out hot air?????
- Water in Engine?
- 351W Factory Head Rework Suggestions
- Anyone done a 32V conversion on a truck?
- 2002 Supercrew with tapping noise when cold
- oil drain plug torque???
- EGR Problem
- Ford f150 starting problem
- Smell of Fuel!
- White smoke from exhaust
- 500 RPM Idle
- 1996 5.0 f150 info?
- Fuel Injector recommendations?
- Proper gasoline storage
- Service Engine Soon P1001, P0401...4 times, 4 days
- replacement alternator recommendations needed
- Starter problem persists after rebuild
- Last day f/Mobil1 at pep boys....
- 99 E350 Hard cold starting, missing V10
- ticking noise in 2003 4.2L
- Vibration noise when you run between 800-1400 rpms
- plug change dilemma
- Coolant Temp and Catalytic Converter
- stroker kits for 4.6 f150
- replacing fuel injector 302 EFI
- High idle and dieseling
- 23.9qt out - 12 qts in... I'm dying here
- 302 EFI missing under load
- 12MPG in 1998 F-150 4.6L
- ? what kind of coolant to use
- troyer p e fan Q"
- 4.6L swap - Possible to upgrade longblock??
- compression ratio
- O2 Sensor 96 Explorer
- Any other ideas about misfire?
- mass air flow sensor
- Please Reply
- strange rattle
- Trying to determine cause of mis / rough running.
- Roadmaster Engines in Houston??
- camshaft holding tool
- COP rubber boots
- Fuel Filter Change
- Other Ford model forums?
- Help, 4.2 oil quantity 8 Quarts?
- 460 flywheel questions?
- 02 Screw 4.6 performance observations and A/C.
- Will Mustang goodies fit on my 4.6
- Do not buy fuel injectors from...
- 97 5.4 Maf?
- Fastest way to 250HP?
- Another p0171 & p0174
- idler arm question
- Starter on F150 '99
- 88' 4.9L misfire
- Runs rough and check engine light
- 1997-f150 Engine R&r
- Clogged EGR related to poor MPG ?
- Cure for all those who have Po171,174
- will it help any
- Bolt on Power choices/ How?
- AutoZone
- Guess what everyone..................
- Can you get an o4 with 5.4L manual trans??
- P0402, P0304
- RWHP for 01 SuperCrew 5.4L
- Trying to pin-point a miss or hesitation....
- Another thumbs up for SeaFoam
- Anyone know where i can help with this? (site or advice) :)
- Cly 4 misfire
- blown spark plug repair in Southern California
- Here's justification for a filter change
- What you think about MOTUL motor oil
- po' boy
- Looking for the on board “Speed Sensor” wire...
- To all F-150 owners
- The New Tick is the new Cat
- Coolant Leak...Please Help...
- This is a tuff one.
- Instrument Cluster...and an interesting observation
- Navstar V8 Diesels
- 1986 distributor question
- CAn someone please tell me how to loosen the belt?
- New Cat but new tick - HELP
- I think I know what it is,,,,but
- 97 5.4 idles gr8t stutters on acceleration
- Oil change after head gasket change
- Has anyone updated their computer codes?
- "service engine soon" light
- codes 1132, 1151, 1152, need help
- Check Engine Codes 171 and 174
- Thanks!
- Whistling Noises
- Check Engine light constantly on. ABS light intermittently but frequently coming on
- Highway Speed
- What socket do I need to change plugs?
- Darn truck
- DPFE Sensor
- knocking sound
- have dead spot in accelleration
- 4.6L Heads/Engine Replacement??
- 5.4 exhaust manifolds
- Need to replace EGR valve
- Flexalite 270 Warning!!!
- oil pressure guage problems
- Siamese Coil Packs?
- Who makes powerstroke?
- sputtering 97 f150 4.6
- alternator problems
- 1987-1991 2WD - Can oil pan be dropped?
- Anyone Using Scanguage?
- Rough Idle, Grinding in Rear End, Check ENGINE light
- Cruise Control not working - No light nothing
- Good one!
- Flying sparkplugs
- Loud Metal Grinding Sound
- Just changed plugs and wires and had oil in wells
- 1995 F150 stalling out
- 200 miles to a tank?
- 5W20 or 5W30?
- Occasionally won't start
- Changing the Fan Clutch problems
- resetting computer after installing a kn filter
- Any Heating & Cooling Guys in the house?
- Blown Spark Plug
- lost a cylinder
- Changing head gasket
- In the market for an F-150
- Gasket and Grease Question
- Clean intake, how?
- This a bad EGR?/Pic Enclosed
- 1996 V8 5.8 L ticking
- 8 new coils, Inj ring kits, NOW WHAT?
- no starter crank
- Need help!!!! Is this a Freeze out plug that need to be replaced?
