5.4L problems
Old Jul 21, 2007 | 03:07 PM
bdyess's Avatar
5.4L problems
Changed out the plugs(motorcraft) cleaned all sensors/valves, TB, when strated it runs rough. I have looked at everything I can think, I must be missing something. Any ideas on what to check next. When in park it sounds really somooth around 2000 rpm, when driving it shakes really bad, even at idle. It ran ok before changing the plugs, just a little hard to start, now I don't know Help please!!!
Old Jul 21, 2007 | 03:09 PM
built54's Avatar
Im going to say you didnt get a cop seated good on one or more of the plugs, ive had that problem, just put on them and move them side to side as your pushing, should seat them. also check all the injector plugs, make sure one didnt come loose. You could also have a vacuum leak, just double check everything.
Veteran: Army
what did you set the gaps to????
Old Jul 21, 2007 | 03:21 PM
bdyess's Avatar
.055 on the gap
Old Jul 21, 2007 | 03:40 PM
bdyess's Avatar
took the first plug out, has a lot of moisture on boot and outside of plug, could this be a reason for my problem???
Old Jul 21, 2007 | 05:23 PM
built54's Avatar
yes... did you wash the engine or did it rain recently?
Old Jul 21, 2007 | 05:46 PM
jbrew's Avatar
If there wet , your screwed..
Old Jul 21, 2007 | 06:45 PM
bdyess's Avatar
I did clean the engine just after the plugs. Took them all out blew them off, put some Di-electric grease in boots... runs like a champ!!!!!!!!!!
Old Jul 21, 2007 | 06:56 PM
jbrew's Avatar
You got lucky , glad to here it . Usually if you wash the motor and get them wet , the COP's are never quite right after that ..
