- Survey of what brings you close to road rage
- what grade oil to use and spark plug removal 1999 4.6
- Please explain piston slap ?? 4.6l Triotn owner 1999
- best way to get at oil filter on 1999 f-150
- Life expectancy of 4.6L Triton
- WHY IS MY 5.4 FQR LEAKING OIL - BADLY??????
- Should I wait until it leaks ?
- EFI to Carb=HP?
- Towing with a 1999 f-150 4x4 4.6l
- Looking for a bed rug for 1999 f-150
- New 1999 F-150
- Ford Diagnostic Codes, Trouble Codes, and Descriptions
- bottoming out, check engine light
- oil pressure guage misleading
- poor heat&defrost
- NEW FQR 5.4!!!
- Lesson 1: Using Oil Color as a Field Test
- What Were the Changes between 95 and 96?
- FYI- 4.6L Intake Manifold Problem
- Engine block heater.
- More Wierd Noises...
- Need 5.8 Lightning donor
- Weird Noises...
- Loosing Coolant
- 99 5.4L Engine Replacement
- New 5.4 Blower Kit !!
- Engine Kind of Blah
- Super Engines!
- Where to buy rebuilt engine
- 4.2L pinging
- Duralube
- Air intake mods with CA emissions?
- 5.8L Engine Swap
- Banks Powerpack for V-10's
- Engine Rebuild Question #2
- Got my F-150, thanks for the advice all!!
- Gas mileage on my 2000 4.2L
- What Year?
- MAF sensor on a 2000
- Accelerator Problem
- Engine rebuild - what to rebuild??
- 99 5.4L Oil Leak
- Pep Boys Synthetic???
- Getting OIl analysis
- HELP?-fuel pump died.......
- Kenworth SUV ?
- Poweraid for sale
- When to install a Superchip?
- Speed density?
- Oil Change
- Best non-synthetic oil?
- Can someone convince me that you REALLY CAN change AMSOIL at 25K????
- Engine swapouts?
- cold weather misfire
- Change Power steering Fluid.
- are the 4.2L's....
- Synthetic oil and leaks
- winsor vs romeo
- Got any trouble free 4.2L stories???
- View of a dressed up 5.4!!!
- Free Airbox/Intake Mod - BOGUS????
- plug wires
- Supercharger Questions
- Hard starting problem
- Proper Break-in
- More Power
- Block Heater Temps?
- Powerstroke V6
- Bizarre Starting Problem
- Police 4.6
- engine cuts out and stalls when air temp is high
- 1999 4.6 how many cubic in. ?
- 4.2/3.8 Recall
- Top 10 Engines
- Expy 5.4 Mileage Questions
- WHY are Navigators so much faster than Expiditions???
- K&N Filter
- Strip times for 5.4???
- Send "em
- MSD's or Motorsport plug wires??!!!
- 1/3 off at CarParts.com !!!
- Ask this question
- How To Clean My Engine With Simple Green?
- 4.6 Triton or 4.6 Windsor ???
- Valves rattling or spark knock
- coil problem...'98 5.4
- B&G Products Found...Info Inside!
- Is a "spark knock" pinging normal?
- 2000 in a 1999 its just fine
- Engines runs after turning the key lock off
- A/C bites the dust!
- 1995 f-150 302 v8 HORSEPOWER? & torque?
- Cruise control problem
- Kenne Bell
- Engine starter relay on 2000s without covers
- Service Bulletins On Line
- 5.4 PISTON SLAP
- Screw Amsoil - USE REDLINE!!!
- 1998 NASCAR edition F-150
- AC Condensate drips on Exhaust and sizzles. Is this Normal?
- Piston slap or lifters??
- 9mm spark plug wires
- which wire bundle fixes rough idle?
- What are the 4.6L power numbers for various years
- Chug at 85mph
- Trading in my '97
- Octane
- Oiling K&N without cleaning
- Engine mis-firing!!!! Need help!
- Oil
- Superchip for Sale!!
- Tach with a V6
- ADDITIVES ANYONE????
- HELP - New 5.4 Ordered!
- Triton 4.6L
- where is the engine block heater?
- Velocity tube install report
- Buying used F150 - Need help fast!!
- Super Charger V.S. Other Mods?
- Service Engine Soon light already?
- 97'f-150 severe electrical problems
- Truck Dies???????????
- FQR Do's and Don'ts?
- Low fuel light
- 4.6 Detonation problem
- Very New at this
- 4.6 engine stalls when dash plate is removed
- Check Engine light & engine computer
- Does the break in actually help?
- 99 Romeo 4.6 Engine Replacement!
- 4.6L Whistle?
- Piston Slap or Injectors?
- Need help finding a 5.8L Lightining Engine
- wiring harness
- Tips on efficient driving?
- Aftermarket V6 help
- Gee whiz stuff
- Vote on the weight of oil you use!
- 93 4x4 302 acceleration
- Engine Swap Help!!!
- Adjust your computer
- MAXOIL
- 1999 F150, 50MPG....
- Preferred brand of gas?
- Leaking timeing cover gaskets on 4.2 l Please read
- spy in the sky
- 2000 5.4L rough idle!
- hard facts on gas mileage
- Anyone with Romeo 4.6L Piston Slap?
- Remote Oil Filters?
- 4.6 Oil Leak
- PCM Modification KA
- How much do you pay for Mobil1 ?
- Reliability of the 5.4L V-8 w/ AutoTrans
- Quaker state commercial
- 2000 engine specs!!!
- Fuel Filter Replacement
- Amsoil
- Mark V111 Heads on 4.6 Truck?
- Vortech's "Super Quiet" chargers now come standard in all complete supercharger kits
- No Response from Engine factory
- 5.3L vs 5.4L
- Is there a TSB for rough idle?
- Honda engines
- Just placed my order for new truck
- A million miles with no oil change?
- Synthetic Oils
- Check Engine Light
- Can anyone summarize 5.4L problems?
- 302 Performance Questions
- What Makes Oil Go Bad?
- Synthetic Oil Actually Cheaper?
- F150 4.2L Head Gasket Problem??
- 4.2L Got 2 leaks
- Hard , cold mileage numbers requested . . .
- Piston Slap Question
- The 2000 way to avoid cold start problems
- Do oil addatives work?
- Oil Filter Removal
- Time For More Engine (302) Mods! Help Me Decide!
- Cold start noises/ getting it diagnosed
- leaking headgaskets
- 4.2L Coolant Leak
- 2000 remote oil filter gone?
- WHERE R THE TSB's??
- PISTON SLAP & VIRGINIA
- any 5.4 problems for the 2000 model ( piston slap and oil leaks)
- dealer says: Superchip,JBA headers, Velocity Tube all violate warranty
- Something interesting.....
- magnacharger
- How do I tell where my engine was made?
- Stock HP and Torque On A 1993 F-150 302?
- Q for Winter "Start-ups"
- 4mpg Milage decrease during winter
- 4.6 belt
- Oil
- What the hell is this blue smoke now??
- 4.6 Triton Spark Plug Change
- High rpm's at startup
- 4.6 rough idle anyone?
- Belt noise on cold starts
- 5.4 gas mileage
- Noise during cold weather
- sticking thorttle
- Velocity Tube install problem-HELP!
- High alt. problem HELP PLEASE!
- free 300,000-mile/10 year engine warranty
- Condensation on the oil filler cap?!
- What's a GEM (sp) module?
- pickup trouble update
- Ford 4.6 vs. Dodge 4.7
- 4.6 pinging
- 3.08 vs 3.55 Axle in 4.2L V6
- Code P1131
- to MAF or not to MAF??????
- engine runs rough at low rpm's
- Gas Milage / K&N filter
- Your best 0-60 times
- REAR END
- It could only happen to me!!!
- Piston Slap in my 97 5.4
- LOW EMISSION TRUCKS & SUVS
- Who has plates that say "FLM MKR".......
- 4.6 L Triton vs. 4.8 L Chevy Vortec
- Service engine light with K&N filter
- RPM's 4.6L Modular Engine
- 5.4 & 5sp Code
- Oil Pan Magnetic Heater
- 5.4L Horesepower Ratings
- burnt smelling coolant
- Service Engine Light
- 4.2 FINALLY Supercharged (was not fun)
- Benifits from upgrading to an aftermarket throttle body?
- 300HP 5.4L
- engine comparison
- 5.4 & 5 speed!
- Thinking About Buying a F-150
- Stumped ! Electrical ??? More problems coming ?
- Can my f-150 win
- Can my f-150 win
- Loud drone from air filter canister
- Tacky tach
- Light ping on acceleration (5.4L)
- what should my rpms be at...
- Small 'radiators'/their function.
- Anti Drain Back Filters
