- Engine coolant question?
- Attn: Screwit
- Octane Shorting Bar
- Need a 4.6l 1997
- Expedition Radiators?
- Are the F-150's going to change in '02?
- why does my truck keep dying.
- Hey Otterbob
- Exactly how similar is the F150 4.6 to the mustang GT 4.6
- Question for BBK/Edelbrock 75mm Throttle Body users
- re-setting computer?
- To chip....or not to chip????
- Lost money on trade because of FQR?
- 4.6 oil leak back after head gasket replacement
- How's your milage?
- Feedback on Haynes Manuals?
- Trans shudder fixed with higher octane gas - needs knock sensor?
- Charging a 4.2 6Cyl...will this work??
- Mass air sensor
- Estimate on horsepower?
- 4.6 vs. 5.4 L ??
- Ported Heads anyone have?
- SD limo
- 5.4 v-8
- Check engine light
- When to trade??
- 2000 Expedition Located in Rhode Island....Place to UPGRADE?
- Which engine
- Power Mirrors
- Update for "Ian.N" Engine tach.
- engine stumbling on acceleration
- engine missfire
- Question for Thf Freak
- Dyno results.......Again
- Sweet car
- Perspective, Patience and Pride
- what service stations/stores use Amsoil?
- Can Somebody Explain ?
- Was just wondering.Flareside or Fleetside??Why and Why not???
- Switch from Mobil 1 back to Valvoline
- K&N FIPK Installed -- feedback on noises?
- Piston Slap!!
- Crank Question?
- 04:04 PM
- Question about 5.4L fuel injectors?
- Installing a "real" oil pressure gauge.
- Performancs Mods for 5.4V8
- Nice Performance Mod
- Spark Plugs
- I like that april fool joke that was cool,hehe
- about to open inlet from fender to 6 inches...any negative effect?
- Blew out the Block heater!
- Reference to Rough Idle concern
- Valve covers for 4.6
- Order a new inake option!!!
- Crankshaft Pulley - Help with removal
- what kind of oil do I use?
- Question for truck experts
- Does anyone know
- Just me?
- Runnin' out of ideas!! -- Help
- WARANTY INFO ????????????????????????
- Mike in LA and RJ -- I need your help!!
- How long to install FIPK?
- Bad Check Engine lite
- billet grill installation/what kind?
- New Chevy C3?? HOW WEAK!
- Engine oil changing habits?
- antifreeze in plug hole
- Regarding the cooling upgrade
- 95 Powerstroke beat my 5.4!
- engine whine
- 90mm maf????
- Improving MPG?
- Rear main seal
- Electric fan question (again)
- 1997 4.2L engine problems
- What gas do you use?
- Looking for Help.
- K&N Air Filter?
- strange engine noise today
- Not really an engine ? but.something is rattling when i step on the brake ?
- 5.4 Tranny
- Heavy Duty Electrical/Cooling Pkg
- Another Question For JSTANG?
- P1141
- Any Piston Slap in 2001 5.4l engines?
- Enginge Vibration
- Piston Slap
- Mustang 4.6 is the same as F150 4.6?
- Pics of true dual exhaust
- firezapper
- 5.4 Crate motors cheap
- HOLLEY THUNDER SUPERCHARGER
- superSCREWED
- MSD ignition
- Wrong Raditor(Dealers reaction)
- Ford Techline says I can't modify my truck
- FINAL FOUR!!!
- Which oil is best?
- Roots style supercharger.
- Superchip ???
- Anyone-Amsoil BY-Pass Photos?
- Header Gaskets!!
- Flex Fan
- Intake tube diameter?
- Changing spark plugs
- HELP! Pinging & knocking
- Any Performance Upgrades For A 4.2L?
- Dealer Competence???? Cant do simple repairs
- Stupid check engine light.....
- Relivin' my teenage years
- NEED GOOD PERF. AND MPG SETUP. HELP.
- Piston Slap?
- K&N Filter!!
- Head Gasket replacement?
- Does anyone buy regular cab trucks anymore ?
- crankcase breather?
- Reset Computer
- Triton Valvetrain Lubrication
- 4.2 to 5.4 switch or Supercharger?
- Is it too late for synthetic?
- 1998 4.6 with real problems...HELP
- mufflers
- Does anybody have 1/4 MILE TIMES FOR STOCK 4.6/5.4 4X4
- Hypertech Power Programmer III, now for 97&98 Fseries
- Please reply --> Specs
- Heater doesn't work.
- Does anyone have Nytling92's e-mail?
- More durable: 4.6 or 5.4?
- If you are waiting for/been refused a new radiator...inside
- If you recieved new radiator...inside
- Does the 5.4l Have an RPM Redline?
- Engine stops-will not start
- Insulating HVAC hoses
- Help! Simple Job Gone Bad!
- what is this T100 i have seen below some f150 badges
- Truck doesn't heat up!
- Speed Limiter
- Fuel Pressure in the tank
- Oil Usage when hauling?
- To Those That Have New Radiators
- any body located Toronto????
- 4.6 V-8 and a 3.55 LSD
- Is ford supposed to provide a rental for warranty work?
- Anyone in the South had Radiator Problem Corrected With No Trouble?
- engine light on/not idling when cold
- Flashing Air Bag Light
- overheating
- 4.0 Ford/4.0 Mazda Same engine?
- 2000 F-150 Piston Slap???
- Damn thing hauls a**!!!
- Starter went out at 273xx
- 4.6 Horsepower
- engine flush
- What have you done since new?
- Is it safe to buy?
- How to test your performance mods on the road....
- new radiator ordred NO problems
- someone once posted, "Is this supposed to be covered"
- 97 Engine Tapping
- replaced 4.6 - 99
- upgrading Spark plug wires
- Radiator Situation
- engine idle...help
- Where is the VAT sensor
- Does a Skinny Radiator = Skinny Shocks?
- HELL OF A NOISE
- How much vacuum on EGR
- mexico
- Oil Line Leak
- Need advise on gauges.
- Service Bulletins at NHTSA
- FIPKs VS Filtercharger
- Question for JSTANG?
- Coolant leak - Timing belt cover $450!?!?!
- Screen windage tray question
- Extended cranking only when partly warm....need suggestions.
- five dead fords on the side of the road…….
- question for steve41
- 5.4 engine miss
- Timing Chains
- airaid filter--what is k&n part number
- How to identify 5.4 w/ 260hp
- Coolant replacement in progreess..........
- what does airflow sensor do.for a engine
- Stock hp on 1998 5.4L Triton - F150?
- Wrist pin going out???
- Recall on short tail pipe???
- Question: switching from synthetic to conventional oil
- throttle cable
- your thoughts on the 97 4.6 v-8
- Best price for K&N Generation II ?
- Ignorance: Whats a blower do?
- Big Mouth/ PowerStack air filters for FIPK
- Low emission vehicle exhaust smell
- Fuel Filter
- Where's the PVC?
- Diect hits ignition systems?
- semi synth oil only for 2001 Fords...?
- Oil Change,,,5 quarts or more?
- Radiators
- Clean Engine?
- Do the 5.4's respond to cooler thermostats
- Purolator Air Filters
- Upgrading Torsion Bars on V6
- won't idle
- 4.6L??
- replace injecters with MAF?
- what do u think?
- original eng question
- Looked at 2000 brand new Lariat LOADED,wrong radiator ?
- Upgrading fuel injectors on a 5.4L
- Diesel V6
- Front end Lift F150...TIP
- 2001 4.6l HP
- Stumbling on acceleration
- Water Wetter?
- Sparkplugs?
- 4.6 Engine timing
- Are performance chips worth it?
- 5.4 Cold Engine Knock
- HP difference between F150&F250?
- Check Engine Light
- Valvoline 5W-20 at NAPA
- Chip Install and a UPS rant
- Larger oil filter be used on remote loccation?
- Oil Filter Relocation
- Fuel reservoir & valve
- Engine Check Light
- Does WMS Velocity Tube use the stock size air filter?
- smoke in the morning
- 4.6 missing HELP!
- Need help with DPFE Sensor
- spark plugs and wires
- What will it do
- Speed-density controlled EFI and a cam?
- Oil inside intake manifold???
- How loud can fuel injectors really get?
- No power to fuel pump
- neal is right about the 8.8 in the trucks!!!!!!
- 4.6 L Oil Leak
- Wet valve cover
- Engine Performance
- EGR Problem - Check Engine Light on 5.4
- Gutless 4.6-
- Reply from K&N regarding FIPK vs. Filter
- What shop/repair manual do you use?
- Online Source Guide?
- An Open Letter To Ford, Re: F-150 Radiators
