Electrical question 2002 Altima
Old Aug 7, 2007 | 10:27 AM
Dave68iou1's Avatar
A friend of mine had issues with his Altima this weekend. Filled up at a gas station and shortly after the car started chugging at higher RPM's. After dumping 7 bottles of dry gas in, the car ran a little better. Took it to a shop and found the battery with no water in it and a strong sulfur smell. Replaced the battery and drove it home 260 miles. Got home to a strong sulfur smell and found his new batter cooked. Not sure where the issue may be. Could it be a regulator in the alternator or between the alternator and the battery? Anyone expierience similar issues? Thanks for any help!
Old Aug 7, 2007 | 11:25 AM
Faster150's Avatar
replaced the fuel filter. check the wire that goes from the alternator to the battery and check the grounds.
Old Aug 7, 2007 | 12:38 PM
Dave68iou1's Avatar
Will check, but could that cause a battery to boil?
Old Aug 7, 2007 | 12:48 PM
Something is causing it to stick on full charge. It's either a bad ground or a defective regulator, which may be internal to the alternator.
The gas tank may need to be dropped and cleaned out.
