bought truck from alaska
I recently bought a truck off of a dealer in nh a 1990 f150 xlt lariat 4x4 with 122xxx and the guy said it came from alaska, now since i bought it it has been running lousy sputtering and it has a slight hesitant when at idle i was wondering if the timing would be different since it was a higher elevation or the idle. Any one have any ideas? Also if anyone know how to turn up the idle on it?
I have driven in the same day from under sealevel to sealevel to 8000 ft above and not seen a differance in my truck.
Thats IMO
Yea, i put plugs,rotor,cap,new fuel lines,fuel filter,engine oil change,tranny flush. The only thing i haven't put into it yet would be spark plug wires because i ran out of money but i will be putting them in Thursday hopefully.
A bad plug wire would cuase a misfire robbing you of power nad making the engine unbalenced. That would give it a sputter.
Should i get the oem plug wires or the performance one's, or is there a difference? There relatively cheap but buying the truck and all it added up quick. The performance ones are $39.99 and the oem ones are $29.99.
X2 but i would do the coil also. I doubt it needs it but at least it would e on teh same page as teh rest of the truck and i dont think there that much $. Again thats IMO.
I just check napaonline.com and there $23. Just one more thing to the list. I would do it if it were me.
ITs probally not a major problem but you might see power/ MPG's gains fomr a better spark produced by the coil.
