Junk 4.6
Old Aug 2, 2007 | 08:43 PM
COORS73500's Avatar
Question Junk 4.6
I have a 1998 ext-cab 4x4 with 4.6 manual tanny. All of a sudden today it started running slugish and like just no power on take off or after shifting gears, no check engine light yet, any ideas???? had a tune up less than 20,000 miles ago
Old Aug 2, 2007 | 08:44 PM
twintips_17's Avatar
More symptoms please. What did you do when you had a "tune up"? We need details.
Old Aug 2, 2007 | 08:51 PM
torkum's Avatar
Also, have you filled up recently? Maybe bad fuel.
Old Aug 3, 2007 | 07:52 AM
Faster150's Avatar
clogged filter or bad fuel likely
Old Aug 3, 2007 | 05:13 PM
Neal's Avatar
Cool
HI!... Change to a 5.4, problem solved! LOL!
Old Aug 3, 2007 | 08:08 PM
F151's Avatar
Agreed on the fuel problem... change filter. run some Chevron fuel injector cleaner through it.
Old Aug 4, 2007 | 09:19 AM
DYNOTECH's Avatar
One of the easiest things to do is clean the Mass Air sensor. I have seen this thing cause more problems than you can imagine if it gets a piece of debris stuck in the meter. Just spray it real good with electronic cleaner or a spray cleaner designed strictly for Mass Air sensors. Don't touch it with anything just spray it. Good luck.
