View Full Version : V8 Engines
- Please help...Rough Idle
- serpentien belt
- Rear End Id?????????
- Big Problems with my truck
- to reset or not to reset
- jl (johnny lightning) address?
- Error Code?
- Synthetic 0W30 Oil
- Stutter at WOT
- Hour Meter Location?
- Powr-flo Air Filter
- what are they doing about the 5.4L engine leak???
- Can you replace a 4.6 with 5.4?
- Knocking
- Finally ready for a Superchip
- Throttle body spacers worth it on 5.4
- metallic chattering??
- High Quality Stainless Gauges
- Is Mazda Ford?
- Starting problems.
- Running ruf
- Ford to trim content of next gen F-150
- Neal!! I found that %#@*!! Leak
- engine problems
- Check Engine Light Is Now On. How Can I Tell What It Is??
- Thermostat
- what tranny comes with a 5.4L?
- Wuh Duh Fuh!!!!
- Mobil1 15W50
- Changing to a vacuum advance distributor
- Idle Speed Screwy
- 5.4 Spark Plug replacement
- factory imposed power delay
- Ram air set up
- What Is This???????????
- what's your opnion about amsoil, how does it work for you????
- Truck stalling-Please help!
- blinking check engine light
- 5.4L and Bosch +4 Sparkplugs...
- Thermostat
- O2 Sensor
- Rumble at take off rpm
- Mobil1 0W-30
- Throttle Bodies and Cams
- Help...will not hold idle...
- Acceptable mileage???
- Fuel Guage
- Aftermarket Lighning parts on a normal 5.4
- Tune Up
- Fuel pressure regulator. What will it do?
- Pinging solved??
- Serpentine Belt Question
- My truck is a P.O.S.
- Spark Plug Boot stuck!
- Please help, More performance desired
- New to me
- superchip?
- TFS intake to F150?
- Who else makes Air Filters for
- Weird rattle noise when starting cold.
- Electric Fan
- throttle body/ mass air sensor?
- Computer troubles? Get one of these.
- Another check engine light question!!
- 1999 Heads Problem
- TERRIBLE Gas Mileage in FX4!!!
- Superchip from my v-6 in my v8?
- 50,000 maintenance
- S&B Filters
- Fixed belt squeel under hard throttle.
- 30,000 mile service
- 1990 diagnostic codes
- I want more air
- when to do first oil change?
- Can I buy O.E. seat covers ?
- 2000 F150 Oil Pressure Probelm
- Decarbonize Engine? Spark Plug Price?
- How To Check Plug Wires???
- Need tech help with MAF sensor problem.
- cruise control
- Question about engine removal.
- Whistling noise found, can I fix it?
- Spark plug replacement
- whatcha think
- Question about rough idle.
- CD2 Engine Cleaner works !!
- flowmaster series ????
- Holy Horse Power Batman...new mods
- Radiator fan noise
- Greasy 5.4l engine
- Problem with trailer lights.
- what is code dtc 5284??
- Door Crack
- Rear Main Oil Seal Leak
- i have a "service engine soon" light...help!
- Gas Mileage Update
- Does anyone know if you can put MSD ignition on a 2001 f150 5.4?
- Black WMS Velocity Tube
- New truck, have an issue, could someone assist.
- Synthetic Oils?
- 300 Straight 6 questions
- Engine cuts out
- ? on Throttle Body
- Noises Fixed!!!!
- any possible engine problems
- cobra vrs. lightning
- Amazed, not an ad though
- Need help on Clattering Motor
- Whose got a surge at startup?
- 98 F-150 intermittent NO-START HELP!
- i HAVE A HUMMMM AT IDLE AND LOW RPMS?
- High mileage V10 and 5.4
- Extended Warranty or Not
- Where is this coolant coming from??
- Code P0401 meaning
- HP & torque Question
- 5.4L Intake Manifold - Plastic or Alum.
- Ever seen a tree hit a Cheby??
- Door ajar
- California Emissions Package ?
- 98 4.6 vs 5.4 Question?
- chrome center caps
- First Oil Change '02 Screw
- HELP! electric fan - engine runs HOT
- engine miss or surge problems
- need an engine?
- CE light, part II. Quick response needed please?
- Help with noise???
- S.O.S. for the experts !
- Confirmed case of K&N air filter screwing up a MAF sensor.
- Pulling a 2001 5.4l from F150
- Reliability risks
- internal engine parts
- Code readers?
- Need help with Nissan!?!?
- Does anyone know all the problems the check engine light indicates?
- Fuel cap, check engine light?
- Check out this STOCK 500 H.P. DOHC 5.4 that FORD is making!!
- Piston Slap??
- air injection from turbo city
- erratic idle after mods
- 4.6L Engine
- brands
- Should I buy a WMS Velocity Tube since I already have a K&N?
- EGR valve insufficient flow
- Bad crank pulley
- Had to post this
- Had plugs replaced and engine light is on!!
- Difference between 4.6L V8 in Supercrew vs Supercab?
- Fipk
- 1997 4.6L dipstick question?
- What does FIPK stand for
- help!!
- 4 valve heads?
- Power Pulleys
- my truck is missing really really bad and it's pissin me the f@!? off
- slugish gas eater ...need help
- Got my short block back from the shop today.
- Do all XLT's come with remote entry?
- Engine Knocking
- Exxon Synthetic Oil
- MSD Stacker 8 ??
- Help! Help! Help! Oh Please Help!
- What's that Popping Sound???
- OT: How to charge AC system
- Need a little help
- Possible Purchase Of Used 2000 Lightning
- I need a part # for remote oil filter
- Electric Fan
- 2001 5.4 Blue Smoke
- What to buy?
- Now I'm confused
- 5.4L vs. 5.3L
- Question about replacing plugs in 5.4
- 4.6 BAD hesitation
- Is The dodge/cummins 5.9L I-6 the new King of Diesels?
- Strong coolant smell at startup
- A tune up this weekend
- Time for some bench racing
- me and my classmate just got jacked...!!
- how often do you guys clean your reusable air filters?
- Cheep code reader?
- mystery engine
- How can I ad factory cruise.
- new 270 Hp straight six
- axle codes?
- Ford Truck- Zero Production
- piston slap
- 4.6 head gasket leak and exhaust smoke related?
- electric fuel pump?.....causing 99 F150 not to start
- What's NEW that's comming from Mobil 1????
- Spark Plug blown out of cylinder head
- salvage yard electric fan kit for 4.6L?
- '97+ F150 Ignition Coil Reliability/Replacement
- Bottle Fed
- 92 5.0 injectors???????
- 2 strokes
- Fuel Filter Line
- Universal Joint?
- Underdrive Pulleys
- Hey Neal
- airforce 1 vs. Mac cold air kit
- Volant Air Intake???
- p_ferlow--->K&N Air box Mod.
- 1992 diagnostic problems...tried everything
- buzzing noise from EGR valve solenoid
- 5.7L Hemi-magnum
- noise coming from engine after body lift
- Strange noise from engine?
- `99 5.4 surges and misses at 1400 rpm to 1700 rpm, help.
- ? regarding air intake systems.
- Engine Ping
- engine rattle noise , not lifters either hmmmmmm
- Found my coolant leak,Check this out!
- Fuel Consumption Log
- injector clean and larger injectors
- Buzzing From Dash
- Finally!
- If you are looking for horsepower, the answer is on Ebay.
- Ordering Amsoil online?
- V6 Diesel?
- FRAM "SureDrain" (again)
- dumb question re: dyno testing
- Installing new headers
- radiator-transmission cooling question
- Oil Filter Location
- PINGING!- 87 octane vs. 89 octane
- F-150 VS. Dakota V8???
- Engine VIN location
- speedometer gear and tire size
- computer code error P0171 and P0455
- My 5.4 is "slapping"!!!
- 5.4L Oil Viscosity
- Rev limit for 5.4?
- Engine oil cooler
- performance intake systems
- When is it OK to switch to Synthetic Oil
- Gen 1 Lightning intake
- Time for a performance upgrade, Chip or Headers
- 1/8 miles times for 2001/2002 F150 reg. cab 5.4 ??????????????????
- My engine oil leak
- Problems With My 4.6
- Battery Light Comes On
- SPark plug and wires suggested? and cutting out
- fuel filter change...
- Burning oil
- whats the best rear end gear ratio for all highway driving.
- truck vibration after seafoam help!!!!!!
