View Full Version : V8 Engines
- new radiator question
- How much power can I get?
- '98 F-150 piston slap woes. Need Help!
- which oil filter?
- Quick!! Please help - Need firing order for a 302 in F-150
- Oil Sender problem
- ECT problem? looking for insight
- I am new here, just got a 91 F-150 w/ a 5.0L
- 7700 lb. GVW radiator
- Fuel additive gone wrong. Please help!
- for any of you guys who have aftermarket headers
- Fuel System Cleaner??
- Love my Truck, Hate my Dealer
- S.O.S. to Neal "the HP Freak" Newman
- 1998 Romeo; clogged cat. converter or "Hydrostatic Lock"
- Moaning sound after engine is shut off
- Rough start-up(cold)?
- extended crank on f-150
- ported and polished
- Exhaust Steam
- Diesel in f150 for 2003
- Will this work??
- Realistic Maximum Trailer weight
- very bad smell
- Do I have Limited Slip?
- Very weird vibration/shake at 40mph
- Fuel Pump, Need Help
- Blower motor
- Misfire cylinder #3
- Now available
- 5.4L head gasket oil leak 2nd time
- Royal Purple Full synthetic
- What Oil Should I Run
- Diesel in Gas engine
- K @ N Air Cleaner Voids Warranty
- Carb./carb. intake for late model engine?
- Engine Swap
- fan clutch
- Need K&N filter part # on K&N FIPK
- Electric Fans Should I or Shouldn't I
- charging problem
- F150 Engine Swap
- Service Engine Light
- Mass Air
- dual exhaust?
- horsepower?
- Horsepower on triton V8-5.4 liter?
- fuel milage loss with air box mod
- Discount ESP Dealer
- Replacememnt Oil Dip Sticks
- What size engine did the 97-98 F-250 have?
- were can I find complete tsb for my truck?
- 1992 F-150 No compression on # 8
- 5.4L Oil Consumption
- "Bucking"?
- Engine compartment cleaning...
- WTF is up with my F150!!!!
- spark plugs, interval for changing?
- Oil change troubles
- 3 MON or 3000 miles, Which one?
- Where was my 4.6 built???
- Maf
- Wicked Squealing At Start-up
- Rate Your F150 By Year
- throttle bodies
- New Radiator?
- Are The Triton Engines the Quietest?
- Looking to get an SHO
- truck dies when coming to a stop-HELP!
- could i have messed anything up??
- Colored Engine Hoses
- Head Gaskets 5.4
- Whats wrong with my truck ?!?!
- Please Help with Noise
- Does anyone know?????
- Superchip and FIPK
- Has anyone recieved there new radiator?
- Tap at start
- Bad noises from my 4.6
- K&N plug Question???
- increased performance
- More Horses
- spark plugs
- 5.4 Liter #6 - No compression
- power steering leak
- Headers?
- Oil pressure glitch
- Gas mileage
- 4.6 Misfiring: Clueless: Help Needed!!!
- how do you rate the 4.6
- computer code
- moaning noise after intake install
- Is this normal for a 2001 F150
- Gas Mileage
- oil level
- Ordering new - Can I do 4.6 w/ LSD?
- Fumoto Drain Valve
- Remote Filter
- Vehicle inf. from VIN number.
- Choke?
- What fluids to change & when???
- 5.4 Head Gaskets
- Air force 1 filter replacement
- Want to add Headers
- Starter doesn't engage
- 5.4 Rear Main leak.
- Obd-ii
- proper engine break - in
- F150 4.6L engine surging/drops out of overdrive
- Still a chance on piston slap.
- Replace belt driven fan with electrc unit
- removeing intake silencer, + air box mod, anybody do both?
- airforce One Installed
- water pump blues
- stupid fuel filter tool
- now i'm leaning towards the f250 power stroke
- A question about factory moonroof
- Thanks To All
- Where is the silencer in the air intake?
- Aftermarket oil pan for 5.4?
- Engine Belt
- Airforce 1 maintenance
- 5.4L Water Jacket Question
- Need help!!! --'99 5.4L SOHC -- Gettin' to the plugs
- Tsb for 5.4 head oil leak
- Ticking noise when rolling?
- No Start Condition
- Chip Or Programmer?
- Please Help!! I need opinions...
- Air Compressor
- Good or bad idea splitting off to true dual exhaust
- Which side is bank 1 ?
- O/T Brake Controller in Engine Bay
- Question regarding Tune ups
- Where to begin?
- 4.9 oil pan questions
- 5.0 to 5.4 swap
- engine light came on. whats the deal?
- How I Wont To Die
- Dodge
- 460 Cid
- sparkplugs
- Painting the plastic in the engine compartment?
- Would like aftermarket oil cooler
- 2003 cobra
- Improved do it yourslf fipk
- Maf Sensor Mod
- 97 5.4L, eating oil WTF?
- 300 C.I. (straight 6) What do you think of the motor?
- New engine for the Screw
- battery or belt?
- tachometer
- After Market Warranty
- traction bars
- Engine Oil Cooler
- what to do with $450. please help.
- High performance heads on `99 5.4??
- spark plug wires???
- Wish List from Ford
- 5.4 vs. 4.6
- 5.4 enough?
- MTBE & the future of gasoline. IMPORTANT
- 5w-20 oil info.
- Coolant Change
- TFI recall
- rebuild 4.6 or swap to 5.4?
- What works best to clean and shine engine compartment?
- Shock Advice
- Need input for aux oil cooler install
- Any advice??? Truck is in with a leaking head gasket.
- ?? for Neal
- how long before tightening?
- Rough Idle 5.4
- Upgrades
- 1994 5.0 Throttle return spring ?
- New TSP, now wont change gears right
- Does Piston Slap still occur? Are they still replaced when it does?
- I got kicked out of the Pinger's Club!
- Need Info. on Triton Engines
- 5w 30 or 10w 30
- AMSOIL 2-STAGE air filter
- AF-1 with winterization?????
- tune up
- 4*4 track times
- TB mod. / replacement???
- Coolant Replacement
- Is occassional ping normal operation??
- Check engine light on @18k
- Performance Upgrades for 4.6 modular engines?
- 89 F150 5.0 EFI misses above idle
- New engines for 2003. Can someone explain what they mean?
- Oil Filter Tightness
- Need to change coil & spark plug
- This time I need some help...
- Metal Chips in oil
- New Coil Packs
- air box and maf mods
- Need Headlight HELP!!!
- Anybody watch the Winter Olympics
- Instrument cluster ?
- Gas filter tool
- f250hd check engine light
- Which Is Stronger??
- New computer with new motor?
- engine miss @ low RPM
- Hey White Elephant, I tried emailing you about your pinging question,
- 4.6L Knocking
- Ideas on what to do with my 'old' radiator?
- Track times??
- high idle at start
- my Ford 360
- Dekstop Dyno
- #2 Coil Pack Out 3kmiles after replacing #4
- 2002 Supercrew 4X4 4.6L Oil leak
- Oil consumption in Chevy 8.1L
- Insulation on underside of hood?
- NEAL!!!! I need your help!
- underdrive pulleys ??
- Air filter kit?!!!
- Head Leak, what's the date of the engine?
- Check engine light came on flashing?
- Lightly modded Excursion running 15.2sec 1/4
- PKRWUD where are ya?
- Chinese Proverbs
- Rebuild info?
- How Much For A Wreck??
- Oil Leak
- airbag is a no-show
- thought y'all might wanna see what a 300 hp 5.0 looks like ..lol
- Help, ignition is crossfiring
- Do Radiator Fans work
- My new F150 made it one week...
- CONS of FIPK???
- Underdrive pulleys & Electric fans
- Headlight adjustment
- fuel sender open circuit
- Rough Idle Corrected
- Help, Code P0302
- Search engine down, need some info on Elec. fans.
- Bye Bye K&N
- JBA headers
- I'm back again
- Best way to clean coolant out of cylinders.
- I wanna be like Neal!
- power steering noise
- The heck w/ a 5.4L
- gas hose?
- Vibration in gas pedal
- How to tell build date of truck/engine?
- forged pistons crankshaft?
