View Full Version : V8 Engines
- my bro needs some help...
- Low End Torque Loss
- Service Work & Aftermarket Parts
- 1999 5.4L Engine Shutoff???
- When to switch to synthetic oil?
- HELP!! Fuel Pump Problem?
- Lifter Tick?
- new guy
- intake, exhaust, header...
- 5.4L Clatters Since Filter Change - Why?
- Sold my P.O.S F-150
- Air flow analysis software.
- 5.4 Low idle...
- Engine "bucking"
- trans. temp. gague
- Crotteau's body lift? Ya out there?
- Ford's Oil Pressure Gauge, I mean Analog Dummy Light
- confused: 5W30 or 5W50?
- Engine Shut-Off at Startup
- factory throttle body size?
- FIPK's???
- How long between synthetic oil changes???
- Does anybody know
- Spark Plugs and Wires
- rpm question
- rattling noise when starting
- My truck is sick....
- intake?
- Help, my new truck!
- Ticking 97 F-150
- 4.6L Mustang
- Break-in Oil
- Break-in period-synthetic oil
- EVAP P0455(2) Diagnostic...all read
- Spark Plugs for 5.4-Real Life Expectancy
- two radiators in my truck?
- amsoil dealers
- Lighting Engines in F150
- Helix Power Tower
- ram air & water
- Bad gauge?
- Engine humming noise
- Exhaust
- Radiator Suit Info
- 4.6L gas mileage for reg cab, short bed 4X4s with auto, 3.55 and ORP
- How much oil in 5.4L?
- 2000 XL Over Idle
- Bad luck or what?
- Intake Question/ Pondering
- Valvoline Synpower
- Underdrive Pulleys - Any Install Instructions/Tips
- Raditor - My take now
- BEST PRICE ON AIRFORCE ONE?
- Under hood liner . . .
- New Holley Street Avenger !!!!!
- advice on coolant change please
- Johnny Lightning ram air kit for reg. F150 reveiw!!!!
- MAF sensor
- What's the deal with K&N, HELP.
- Hesitation on '97 4.2L
- Air force 1 or K&N
- heat related fuel prob?
- F-150 Radiator Update from Ford
- will not shift into drive until let off gas?
- fuel pump running all the time solved
- 5w20 Oil
- Mass Airflow Sensor Mod - Worth it?
- 1995 F150 300 6-cyl MPI
- K&N took a dump
- Here's a new budget air intake....
- modular engines?
- changeing plugs in a 4.6L
- How much piston slap is too much?
- Plugs & Wires
- Are fuel injector cleaners worth the $$?
- 4.6 manual reg cab
- Check engine light just came on?
- Braindead Engineers
- Tornado Air Management System?
- Ok,which is better Zaino Bros or Cherry Wax and where do you buy them
- Velocity Tube vs. other FIPK's????
- FAN STOPS WHEN ACCELERATING
- whats the best wax / Nu-Finish ? Astroshield ?
- EFI Tensioner - 87 F150
- Voided Warranty - Your Experience
- Can I replace a V-6 with a 4.6L V-8?
- K&N Air Filter
- What's the difference?
- 99 F-150 Rear End Size?
- serious problem with 4.2 v6. Help?
- Engine Mods
- is the FPIK supposed to suck?
- Really Bizare Temp Problem
- Header Coatings?
- K&N Filter cleaning????
- check my engine
- cleaning air filter for Air force one
- 2001 XLT S/C V6
- ATTN: Those who've taken slack out of accelerator cable.
- Electric Fan Bolt on kit needed?
- TSB wrt 5W-20 oil in 2001 F150
- Gas Milege
- PRE-DETONATION , Dieseling???
- radiator replacement in Baton Rouge
- Check Engine Light / Gas Cap? Reset?
- Has anyone had their radioator replaced in the philadelphia area?
- $100 bucks for wires???
- Changed plugs,wires,airfilter,fuel filter..still runs like crap
- Squealing Fan
- URGENT URGENT URGENT
- rough idle & oil disappearing
- Were can I buy a Rebuilt 302 Engine
- Rough Idle/Engine Miss fix for me
- Mass Air Flow Sensor Upgrade?
- Radiator help please!!!
- spark plugs
- 4.6l gas mileage
- throtle body coating?
- 4.6L Engine with 5.4L head's
- Any sites that have pictures of 4.6l breakdown and internals?
- splitfire plugs
- How much oil in straight 6?
- tps adjustment and pcm
- Sensor Problem??
- Wrong Idle
- Engine code
- to all the electric fan people, ever hear of these folks
- 75mm throtle body
- Exactly where is tranny radiator?
- Are my CATS plugged?
- 4.9 engine barely runs
- Jingle?
- Lightning 90mm MAF
- Thoughts on Amsoil
- Plug Wires
- electric fan question
- 4.6 sounds like a diesel
- Weak Bumpers????
- Locating PCV valve
- I am in LOVE!!!!!!!
- Low Idle-Engine Miss
- Supercharger at high altitude??
- Increased 5.4L Gas Mileage
- Question about Mobil 1.
- 5.0 conversion '97 f150
- Changing Fuel Filter on 1997 F150
- Best place to buy color matched bug deflector
- engine spark knock
- Y Pipe
- Fuel Weight??
- ATTN: Jim Wright
- Where's the computer in my truck?
- Does more air in need more fuel in as well??
- Halo spark plugs
- Oil on my spark plugs?
- Part # on teminal block cover?
- I got the mods, now what's my HP?
- New to the borad
- New member , need help
- Airaid FIPK, is it worth the money?
- 2002
- 302 EFI swap to 460 carburetor
- New FQR Motor w/ PI Heads
- '84 F150 water pump pulley
- Fuel gauge gone screwy
- 4.6 Takes extra oil
- Misfires Lots of them!
- Is your F-150 afraid of water???
- Piston Slap? on a 2000
- Oil seeping every where
- PCV
- Oil pressure guage conversion
- Problems with Gen II FIPK
- Spark Plug????
- Want better mpg? Step on it!?!?
- Does the 4.6 have coolant drain plugs in the block?
- Oil drain plug markings????
- Headers
- Hi & Lo mileage the same
- Your Opinions on Auxillary Engine Oil Coolers
- Synthetic @ high mileage
- 1st Truck and loving it
- 1987 F150 runs rough
- PCM Set for 104 Octane????
- Help with plug wires 4.6
- A/C Problems?? URGENT GUIDANCE please!
- future motor
- Engine Tick
- how many miles till i can stomp on my new engine?
- truck warms up and quits. Starts again when cool
- installing shorty headers
- WMS velocity tube
- Question about "PI" heads.
- Ford is not the only manufacturer with piston slap motors!
- MPG with powerstroke ???
- Pace Setter air intake
- Synthetic Oil in 302
- High flow Y pipe 2nd
- please help
- Won't start
- engine upgrade
- '99 5.4L V-8 Blew Spark Plug
- Engine Break In Period
- airforce 1-service engine light
- Older truck question.
- radiator ordered and other tow package questions
- 95 F150 Oil Pan Remove
- Mobile One at 60k
- A/C clutch sticking
- 10w-30 vs 5w-30
- which powerstroke chip to get?
- This is THE F-350 I want.
- any suggestions
- '98 ===3.0 sparkplug gap
- Service Engine Soon ?
- got a couple ?s
- High flow Y pipe
- Extended warranty
- Radar Jammer do they work
- Truck in Shop 2weeks and counting (motor replacement)
- ? adjusting new TPS
- horsepower
- please help
- fast idle?
- Better gas mileage
- Wrong Radiator
- oil filter relocation
- Home made intake
- Mobile1
- Where can I get Amsoil at good price?
- Performance idea...please give me our opinions...
- RPM SURGE
- Post your sidegapped plug results !!
- RUNS ROUGH
- MAF and Injectors Upgrading Question
- Will 429/460 Engine Fit in a 1998?????
- HELP ME,, i need to convince parents to get F150
- Decoding the VIN
- superchip, flip chip. whats the difference?????? help me please.
- "NEW" motor sign in (piston slap, oil leak.....)
- 42 Injectors in Cobra???
- 302 to a 347 Engin Rebuild
- Are ALL V-8's called 'Triton'?
- K&N air filter question>
- 351 Windsor Horsepower
- Post here if your 2000 came Factory Equipped with 2.20" 2-row Radiator
- 5.4 magnacharger must sell
- Wacky idle revisted and cold natured 4.6
