View Full Version : V8 Engines
- Plug blow out tally,only post if you had a plug blow out
- Making the move to electric fans
- Idle Problem
- 300 6 engine hop ups
- Price Comparo for Servicing
- oil pressure
- I think the head has to come off
- Thanks All of you that answered my thread!
- Who is in the 100,000 mile club?
- This is scaring me!!!!
- sick 97 f-150 4.2 (ideas)
- Good amount of smoke coming out of exhaust
- Urgent Help Needed Please
- how much should i pull in o/d
- 2nd gear RPM loss
- Electric Water Pump Or Pullys?
- Extended Warranty Question
- 2001 5.4 Starting oddity
- Did a "mini-tune up" today......
- FIPK filter kits
- Oxygen Sensor Location
- Pullys? Do they free up 12HP?
- Cold weather miss...
- throttle bodys
- Engine studder at low RPM's
- Antifreeze smell
- Engine Missing during Acceleration
- stumped by oil leak from air cleaner
- What's happening when I "Punch It"?
- Loser smashed my F150
- 5.4 litre problem
- Fixed the "Ping"
- K & N filter install
- Need a little advice on Coolant change--->
- Need a little advice on Fuel Filter changing--->
- Accel Foam air filters
- oil change easy question
- 4.6L redline
- What Brand Of Oil Filter Are You Using?
- start up whine
- Fuel economy
- '02 SuperCrew Wouldn't Start??
- starter noise
- #3 Cylinder Running Lean
- Throttle body Q.
- should I be worried about blowing a plug on my 01 5.4?
- Think Before You Chat
- Throttle Body Spacer and K&N Drop in
- Pinging 4.6 owners, one more thing to check out
- Recent experience with Coils and Plugs
- Missing, shuddering, pinging all around 99,500 miles..
- I have a problem with my idle can someone help?
- Amazing!!
- Ford may not offer new V6 diesel
- Help 01 Screw died on me twice tonight
- Idling At Start Up And Oxy Sensor, Shocks Too !
- thermostat question
- mpg help?
- How do you change the antifreeze?
- 4.6/5.4 I need recommendations
- 1-2 shift, engine hesitation
- Gas Mileage loss, reving engine
- Ignition Coil Pack
- Rough running 5.4
- blown plug
- Spark Plug Blowout in 5.4 Triton Engine
- ? about changing oil pump and stuff on oil cap
- Ticking noise when first starting up?
- E-bay Air Intake
- Has anyone heard of Nology HotWires
- Code 0174
- Serpentine belt
- Fix For Bad Heads?
- Cause of BOTH P1131 and P1132???
- Maybe someone can help me clarify something.
- new plugs(wow)
- 5W40 Synthetic?
- cold start problem 4.6
- 5.4L CNG engine same as gas engine??
- Rattle sound on 4.6
- Looking for a mat to park my f150 on in garage to catch water?
- Oil, Lower Pulley
- AFE intake kit!!
- sticking accelerator
- HELP - Exhaust question for 1993 F150 FlareSide with a 5.0 motor
- Any thoughts?
- Supercharger gone - Installed KNN Air Intake in 99 F-150
- 4R70W with Lightning 5.4
- Who here is COLD today
- Help !
- Filter Change Only, How Much Oil????
- having problems with my 4.6
- Idle speed
- W type engine?
- '97 4.6 to '00 32v Navi 5.4
- Won't start in park
- Raced a V10!
- Throttle Body cleaning
- 3 valve 5.4 liter - availability?
- Changing plugs this weekend, what other things do you guys recommend?
- Rough idle for 15 seconds
- Making Speed
- So I still have a problem with my 4.6.
- Just finished changing plugs...
- Lightning Motor upgrade
- Head Swap
- Power Steering RIP
- motor swap
- Should this worry me or not?
- Any One DYNOED there Truck 4.6/5.4/6.8
- Does the 4.6 hold 6 full quarts of oil?
- Warranty Concerns
- interesting article about oil
- my truck with hard starts
- MAF size
- 02 HD Stalling
- V-10 Superchargers?
- Service engine soon light
- velocity tube??
- Cold Weather Knock Knock
- Added K&N now check engine light on
- 1999 f-150ownerswiththe5.4pleasereadthisandthethread"BLOW N PLUGS,DAMAGED CYLINDERHEAD
- FIPK on SD didn't work...
- Helix Power Tower...BAH
- Powerstroke?
- New DPFE sensors are absolute junk
- Change engine oil every 3,000 miles or every 3 months?
- Fuel pump location
- Pinging
- Ready to install 2000 LIncoln Fan ...
- 94 F150 Overheating
- PowerAid Throttle Body Spacer for 5.4L
- Throttle Body build up?
- How do you get sludge out of an engine?
- OBDII Question
- truck is running like crap
- To Cam or not to Cam?
- Suggestions on Headers Please!!!!
- test
- Motorcraft double platinum plugs
- piston slap??
- Help! Changed wires, missing worse than before!
- 80,000 Mile Tune UP
- High Idle after mud bogging
- What constitues warranty violation?
- where could the oil be from?
- Driveline vibration??
- Moaning sound from FIPK????
- Synthetics seem popular
- quick release oil drain plug
- HELP Quick!!
- Oil pan question?
- going from dyno to synthetic????????
- AEM Brute Force
- Gas Line anti-freeze?
- Pics of your Ram Air system
- Need pics of Amsoil dual remote set-up on F150!
- AMSI Air Filter Kit
- No Start: what could have happened?
- Any prevention for blown plugs?
- Purolator oil filters?
- Po133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
- Amsoil vs Mobil 1
- dry start up
- Havoline synthetic
- Need Recommendations on Scan Tools
- 2003 Engine Whine
- Making a 4.6 150 faster
- 2003 Mustang heads on 4.6 f-150
- Dyno Test
- Air Flow
- piston slap not fixed on 2002!
- Mobil1
- Idle Surge
- Which engine sells most?
- What Engine??
- Mobil 1
- Help! Excessive EGR flow on 4.6L!
- New Plug Wires, Whoooooo! Also, coil pack ???
- Buzzing Noise Behind Dash
- mobil 1 useage on older motor
- Larger size oil filter?
- Any help on the way for the 4.6?
- Oil Leak
- New 5.4 coming
- Need some help please.......
- Gas in vapor cannister, vapor lock?
- 2001 HD F150 Engine question
- Borken fuse box latch...need cheap fix
- Belt
- FLushing Coolant Question-------->
- 235 vs 260 HP
- 4.6 4wd Overral Mlg 15 Over 2 Yrs
- Need to vent...
- 5.4 Oil filter removal
- My 4.6 needs help
- Power steering fluid change
- stoking out a 4.6 L..
- Engine Coolant Gauge
- Got my new engine
- Smaller Pully's, Warranty, Throttle Body Spacer
- Irratic Idle
- PS issue and 4.6L questions
- Oil Vicscosity Consensus
- Spark plug...Heat range
- any suggestions on cleaning the IAC?
- K&N Intake
- Question about engine ping
- DPFE sensor at Autozone
- Oil Filters
- JBRIII or anybody else with Motorsport wires
- MAF Mod
- Bad Gas Milage
- Rough running
- What to look for 99/00
- What is "Failsafe Cooling System"
- Ok guys this decision is killing me,new Chevy or new F150?
- coolant leak?
- Broken Studs on Wheel
- computer codes
- need info on rough startup,PLEASE!!
- Just cleaned my MAF, question now.
- Computer Chip
- Do thunderbirds have distributors??
- New Guy, I need some Q/A....
- new '03 engine question
- kinda cool
- Spark Plugs. Which are best?
- '97 F-150 4.6
- oxy sensor testing?
- Muddy Engine/Slight Hesitation
- spark plug trouble
- power steering??
- Wierd Smell
- Who has N20
- How hard to change plugs in 1999 5.4 expedition?
- Starting problems!
- I need help...quick
- Start Problem
- Plus 4's
- Speed sensor....where is it help please
- Pinging 5.4
- Yikes! 500.00 for a tuneup?
- 11.8 Wtf???
- Adding a REAL Oil Pressue gauge, drain first?
- crazy oil pressure gauge
- cooling system / heater core
- Fuel Additives for carbon removal?
- Ebay Repair CD's
- '03 Power Steering Noise
