View Full Version : V8 Engines
- Buying a '90 4x4 - what to look for?
- Timing advancing
- header+4.2L
- chargers
- 2001 F-150 changes?
- power pully's
- billet grilles
- Air Raid vs K&N Gen II
- What Constitutes 'heavy duty cooling' with the tow pkg?
- Annoying detonation
- QUESTION FOR MIKE T RE AIR RAID
- Need 1994 F-150 Repair Manual. Help.
- Service Engine Soon... Again?
- sensors
- accel?
- 5.4 v-8 on super duty 4x4 xtracab enough power?????
- Another satisfied WMS user!
- Oil, Filters, 'final answers' and... where?
- Fan questions!!!!!!
- AirRaid Users - Are you experiencing whistling noises??
- what type/brand of electric fans are people using?
- FIPK with stock exhaust and superchip - good idea? Please help
- Just did an air box mod.
- Question about open element kits?
- Problem with factory tach.
- Shop Manual, where to buy, what brand?
- DEX-COOL
- Coolant capacity
- SHOW YOU ENGINE HERE
- blowing blue smoke outa my... rear thingy hole??!!
- Vortech on a 5.4L
- Do you know what this is?
- 1990 F150 Fuel Injecter?
- HOW TO CHANGE PLUGS IN 5.4??
- 5.4 & Rear Main Seal?
- Good shop for custom Turbo headers/plumbing?
- K&N FIPK: slow to CARB approve for 2000 models
- Engine ticking
- Help!!
- rough idle/engine miss
- Dumb Questions regarding MAF Mods
- Hestitation/Surging
- 93 302 to Cobra swap?
- Oil filters
- Magnacharger Pics (uninstalled)
- HEY FORD BOARD MONITORS!!!!
- Few ??'s
- HAND PORTING "99" ABS 80MM MAF?
- Accel Coils and/or Jacobs DIS for 5.4???
- HP and TQ
- 2000 5.4L Triton 0-60mph in ?
- Best Price on Jacobs Ignition?
- looking for bugman!!!
- calling Jackhel with pd supercharger
- ? for What Ranger? about Flex-a-lite fan
- 1/4 Mile Times?
- Slight ticking sound when at idel ?
- Anyone Please Help!!!
- Cleaning MAF Sensor Seems To Cure Pinging
- Powerdyne SC still sucking wind!!! (but not giving me any!)
- Ok, 93 302 blew a cylinder what now?
- Fuel Pump Info
- HELP!!! Order a 2001, or keep 99'?
- Help me cool it down, E fan? New Thermo?
- 302 to 351w Swap
- Spark Plug Wires???HELP!!!
- AC NOT WORKING....ANYONE ELSE?
- Check Engine Light
- Curious about 5.4 engine in F150 x-cab
- noise from engine
- 100% synthetic???
- Installed my Outerwears
- pennzoil
- Oil Leak (front of block)
- Can you use velocity tube & pro-m & tb
- 4.6 4x4 5 speed
- Question About Synthetic Oils
- engine knock/rattle
- Please Help Me With Injectors
- V10 Spark Plug Blow out
- How to hop up a 93 302?
- Oil Testing
- RPM Drop while accelerating
- Jacobs Ignition
- STOCK F-150 FUEL PUMP VS. LIGHTNING's FUEL PUMP?
- flat spot in 3rd gear/entering highway
- 4.6 4x4 5 speeed
- Jacobs DIS and spark plug gap?
- K&N filter
- Jacobs with Accell coil packs
- Superchargers
- WMS Velocity Tube?
- Platinum gas saver???
- f150 pulling capacity
- Engine Oil Capacity
- Cleaning Engine
- PART # FOR BOSCH PLATINUM +4 SPARKPLUGS FOR "99" 5.4?
- Royal Purple motor oil
- Engine stalling & hesitation
- Takeoff Lag
- engine rattle
- heater hose Inlet to heater core
- 4.2 vs 4.6 vs 5.4
- jet noise
- Synthetic Drain Intervals
- K&N vs Airaid FIPK
- V8 - 4.6 or 5.4
- Synthetic Doubts?
- Heat Wave
- When my truck need a change of fuel filter.
- t-body and airaid are now 75mm
- cleaning a mass air sencer
- Ping, Ping?
- VALVE RATTLE
- headers and high flow cat. converters
- K&N FIPK Problem?!
- Performance
- just a test
- Go ahead....SLAP me
- Whistling Noise?
- Smell of Oil
- Gas Mileage
- HELP!!! - Suping-Up my 1992 5.8
- Antifreeze smell after engine has been shut off?
- Hesitation
- Reving, How much is too much?
- Question about a new truck.
- Cat Converter Noise
- LOOKING FOR HEADS
- best overall modification
- Idle mixture adjustment
- to much gas
- water leaking from under truck
- MAF HOT!!!
- Complete intake package for maximum gain?
- Low Fuel Light on while engine is starting.
- Engine Noise or Antilock????
- engine fit in bay
- Poweraid, Dyno Report 5.8 (just call me a sucker)
- Radiators
- Antifreeze in cylinder
- Rough idle
- Old airbox???
- Where can I find info on Velocity Tubes?
- hesitations, pooch
- larger throttle bodies do they help???
- gas consuption
- Anyone heard of Airforce One?
- 5W/30 & 10W/30
- miss at idel
- ZMax additive anyone?
- 330/281 engine applications?
- 10 dollar mod that works !!!!!!!!!!!
- More power, more heat, lets cool this bad boy.
- Granatelli MAF Sensor
- Miss under load
- Magnacharger!
- Camshaft for 5.0
- F150 running badly hot
- Mobil Delvac?
- JMC or Neal, TB porting???
- hypertech power programmers
- Poweraid Throttle Body Spacers and Throttle Bodies
- miss in the engine
- '96 F150 Temp Gauge Problem
- throttle body linkage
- Venting! damn ford. Get this.....
- 4.6 Rod nock and bering noise
- Synthetic Oil
- '99 4.6 GT Heads on '97 5.4??
- 1999 piston slap
- Jupiterak's new identity
- Moblie 1 oil consumption
- What about the Vortechs
- New '99 F-150
- Anyone interested in 1/3 off at CarParts.com
- Checking Vacuum
- wiring harness diagram
- 5.4L Rough Engine Idle
- Size of TB and MAF
- My psychic friend sees a supercharger in my future.
- im a full member in one day
- Monkeys flew out my butt today.
- 5.4L not running well
- Anyone with a aftermarket MAF???
- Yet another airbox mod (With PIC's)
- bad bad news from kevin 3636
- NEED HELP ON SERVICE ENGINE CODES
- Want to change Motor Oil Brand--O.K.??
- RPM Redline
- 2003 F-150 Pics
- First Oil Change
- Question About Ethanol
- Still not impressed w/ this motor.
- 4.6L Sounds Like A Diesel!!
- Throttle body
- Throttle body
- "Check Engine" light
- towing capacity
- when does a 5.4 get 300 hp is it 2003 or what
- Smokin' the Tires
- Bid Blue has a cold....
- governed 4.6
- looking for camshaft and headers
- 5.4L Power
- Detonation......GONE!
- Slapper Replaced...Finally
- What would you do for the perfect truck?
- fuel systems 2
- fuel system problems
- Reseting computer on 2k f150
- powerdyne supercharger on my truck
- new engine in....:):)
- Just wondering what you guys are getting for fuel mileage on the 4.6L 4X4's?
- 4.6 with low compression? HELP
- Outerwears Prefilters
- Need some help!
- Hey there
- want to change the plugs...or do I?
- Air Box Silencer Removed?????
- 17.09 @ 84.3, soon to get better
- '97 4.2L V6 Overheating; any suggestions?
- Major problem with K&N or HOAX!!!!!
- after cooler on a powerdyne supercharger...
- powerdyne supercharger ships today,
- oil drain plug
- syenthic oil
- Did I do the right thing? Bummed out!
- 4.6LV8F Earns "Highest Volume" title
- K&N Aircharger Kit vs. FIPF
- Synthetic convert
- Any custom ground cams yet.
- Short in Charging Circuit?
- Can anyone comment on this?
- Engine Torque Curves (4.6)
- What octane for a 5.4L V8???
- Spark Plugs and Wires
- question for WHAT RANGER
- Electric Cooling Fan or Stock Ctutch Fan?
- 1/4 mile times = 17.09 et
- Marvel Mystery Oil
- Fan Belt size
- spark plugs
