View Full Version : V8 Engines
- Vibration
- 99 f150 4.6 v8 engine squeaks
- Romeo vs. Windsor durability question; also Mobil one question.
- What makes triton?
- How To Safely Clean Engine?
- Supercharger and Octane help?
- Ford Website
- Where was my 5.4 made.
- Piston Slap
- Hi 5.4 initial start idle
- New K&N Scare
- 84 F-150 Rebuild
- Does my warranty cover it?
- NEW F150 OWNER
- Gas Mileage vs. MPH
- ASP Pulleys A word of Caution
- dual tailpipes and no mufflers?
- Underdrive Pulleys & Throttle Body?
- Selling my 2000 f150 Lariet 4X4
- F150 Piston Pics
- 4.6L Starting Problem
- Velocity Tube Not That Bad
- 4.6?
- Chipped 4.2L quicker than stock 5.4L?
- Airaid Users: Would You Buy it Again?
- Need help with "Service Engine Soon" light
- KB Blowzilla for 5.4l
- Belt Driven Fan HP and MPG Penalty
- Vibration at 2000 RPM in F-150 5.4 eng.
- 5.4L and Ford!
- Market for used SVO (Powerdyne) supercharger?
- Remove air tube?
- '94 302 & K&N FIPK - Rash Decision
- Need help figuring my engine mfg. date...
- How many people do and don't have an uneven vibration at idle?
- Lower MPG when computer is in learn mode?
- 2000 5.4L wants to die when I first start it in the morning.
- ford engine
- SVO Heads, Intakes, Roots Superchargers???
- Pining/Detination
- Misfire Cylinder #2 on 5.4L
- Am I Getting the Run Around on My Slapper Replacement??
- What is AIR SUSP?
- Should I Engine flush
- 5.4L Slappers and Fords Customer NO SERVICE
- Install a Preluber?
- Where can I find info on triton engines?
- Need more low end torque?
- Pulled off Superchager
- 4.9l off-idle hesitation
- 4.6L with 5spd and towing
- veloci tube sucks
- are throttle bodies really worh it?
- Detonation on 1997 4.6L
- noisy starting 99 4.6 w/mobil 1
- Perfomance of a 5.4
- Throttle Body
- 351 windsor
- Tune-Up Costs
- Reset Engine Computer -- Odd downshifting?
- 4.9L ....want more horsepower,what do I do?
- scanner fo codes
- Engine swap question
- how many grease fittings on 99 f150 4x4 ??
- popping noise
- Intake Silencer Removal
- Adaptive Computer
- Questions
- Test
- Anyone converted to propane?
- Check engine light anc gas cap
- 4.6L lag
- Lease Amts?
- HELP ME
- number 1 and 3 cylinder misfires
- Noise from Engine compartment
- Motor moan
- 351 into 97 f150
- 99 5.4 owners, a little help?
- K&N Filtercharger problem
- Quick question....
- Ready to order 5.4 or 4.6 for Supercrew???
- new and different engine sound
- Can't find alternate source for Piston Slap info
- What is better
- Speedo gone wacko
- lightening engine
- K&N Question
- Adding a Tachometer
- Where to get a Tornado, airaid etc.
- Engine Analyzer 3.0....Anyone Got A 5.0 For It?
- How Much $$$ Have You Spent on Engine Mods??
- Speed Density To Mass Air
- Rough idle from tight binding tolerances?
- @75000 miles Is it too late to change to a synthetic oil?
- Pep Boys Synthetic Oil
- V8 engines in F150's
- Dirty Engine!
- Mobil1
- Which 351 In A 1978 F-150?
- MANIFOLD HEAT SENSOR?
- Motorcraft FL-820 , FL-820s Same Filter ?
- Door Ajar???
- Popcorn anyone?
- 5.4 vibration / O2 sensors
- still have problem
- Edelbrock/BBK Throttle Body Questions...
- Synthetic - How do I get all the old out first
- Oil choice for noisy starting 99 Romeo 4.6
- 5.4 replacements -higher horsepower?
- Plug Wires/4.2 ??
- Re. Silencer removal
- 5.4 Piston Slap Factory Fix Date?
- EEC V (OBD II) Code scanners
- another potential reason for rough idle/ idle vibration????
- Follow Up! The Smell of Oil?
- Super Charger or 4.10 gears what would be best
- Buying out my F150
- o.K. to start using synthetic oil at 32,000miles??
- Jacobs Ignition in 5.4
- 5.0 engines
- exhaust flutter
- chevron techron additive
- magnuson eaton superchargers
- NW Fla F-150 Owners Unite
- 4.6 Oil Capacity Question
- Help! Strange engine things...
- Air raid for v6
- silencer
- dynomax exhaust -vs- flowmaster
- New 4.6/Wrong Dipstick?
- f-150 questions
- K&N
- heyGROP,HOW BOUT them JBAs
- Superchips a disappointment
- Explanation of hp vs. torque...?
- Reading plugs???
- More Piston Slap Woes
- 5.4 ?
- 4.6 What mileage life can I expect?
- catalysis converters/O2 censors
- Changing spark plug wires
- 4.2 engine recall
- Jackhel whats your secret to these 13.7 1/4 times
- TRITON IDENTITY
- new thermostat 180 or stay with stock
- Magnacharger Info.
- 1998 5.4 F150
- Need Advice On Kenne Bell Supercharger
- Worn carb
- engine sluggish
- new ford engines in future
- O2 sensor - improved milage?
- Minnesota area members
- 4.6 FQR
- Stock 4.6 HP?
- supercarger info
- Replacing the Starter (1990 F-150, V8 5.xL)
- Extended Warranties
- FI50 TOPS OF FULL SIZE!
- Red Neck Games with big trucks
- 4.2-v6 engine nosie?
- Bosch Platinums. Worth the $$$$ ???
- Need info on Royal Purple synthetic oil please!
- 5.4L Gas Mileage
- power dyno supercharger on 4.6 1997
- free O2 sensors
- Has any one got their timing cover re-call yet??
- Everything you ever wanted to know about gasoline
- Won't Start
- 4.6L After Mods.
- Block Heater
- Rough idle
- Warranty Questions
- installing a 5.4 engine?
- Power Questions
- Supercharger (for Neal the HP Freak)
- Rocker arm question
- Will Synth. oil void Warranty?
- Does my `97 have an FQR engine ??
- WMS Velocity Tube
- 'Royal Purple' syn. oil...any reports??
- 1999 4.6l
- 351 fan clutch vib!
- Do You Know Where To Buy K&N Air Filter
- Performance for '91 Ford
- Spindal Lift?
- Truck Wrecked, selling performance parts.
- Warranty
- piston slap on 4.6 1997
- air intake for v6
- Engine pinging what does it sound like?
- anyone hear WMS group buy?
- Street Night tonight March 17 @ Texas Motorplex
- Oh yea
- k&n for 2000
- FQR Engine Whining At 2,600rpm
- Airbox mods PART 2.
- OIL
- Synthetic Oil Is it time
- Where do I get the Embem @ a cheap price?
- Changing to Synthetic
- 5.4 or Supercharged 4.6 ?
- What gauges??
- PSD Intercooler on a V10
- 75mm Edelbrock TB for 4.6/5.4L
- Has anyone tried pennzoil synthetic?
- Cleaning Throttle
- 4.6/5.4 PCV valve
- 87 octane? 1st oil change?
- I just hit 72K What now?
- The Smell Of Oil?
- Swapping A 4.2 ????
- fuel fill
- AIR-BOX MODS>
- I have several 4.2L V6 questions
- New Lubrication Forums
- Timing on 351 Windsor
- 27.5 gallons in a 25 gallon tank. how?
- Alternative fuel conversion kits?
- Squeking Noise From Engine
- overhead cam oil usage
- 5.4 concerns
- Gas Mileage vs. Oil Level
- 4.6L Engine Oil Leak Fixed
- B&M Pump Whine
- Rough Idle Seems To Be Contagious
- 4.2 Owners (kind of long)
- spark knock
- Has anyone ever had a problem with synthetic oil?
- 4.2 liter bolt pattern
- writer looking for Texas truck owners
- I think I fixed my rought idle
- What is best oil filter?
- Turbocharger
- DEAD 1999 5.4 XLT 4X4
- Engine idle speed
- Synthetic oil
- Roller Rockers cut your hp/torque
- warranty work
- Bore and stroke?
- 5.4 LTR Motor question
- Is the 4.6 Windsor faster than the Romeo?
- Still more V10 problems
- Replacing fuel filter at 30,000 miles.
- engine problems ( 5.4 )
- White smoke
- Low fuel light, what does this mean???
- PVI technology is it real or crap?????
