View Full Version : V8 Engines
- For those who had their head gaskets replaced. PLEASE REPLY HERE.
- Junk Ford Engines
- Alright, now i'm scared! f-150 are good but all these problems!
- Can I check and see if the odometer is legit?
- Whats with the oilfilter location.
- People who had engine replaced
- Airbox Question
- Ford V10
- Miracle oil / tranny / fuel additives...
- Rough engine @ 1400 RPM
- Redline fuel system cleaner,amazing!
- Synthetic oil
- OK, i'm new in here, can you all give me some tips & tricks for a little more HP???
- Exhaust Systems
- burnt antifreeze smell
- FQR Engines
- HP estimation
- FQB/FQR = ?
- Ford Extended Service Plans
- Miles per gallon, F-150 and Superduty's
- diesel or gas?
- Diesel in F-150?
- low temp thermostats
- 4.6L Oil Leak
- 2 problems
- Oil Filter Location
- K&N fipk Generation 2 part number
- ??'s for those with FQR engines or heads.
- When truck comes to a stop engine idles rought
- tornado intake spacer
- Fan problems
- TWO YEAR OLD VIBRATION
- Can someone clue me in on 2001 5.4L?
- 97 Expedition 5.4 stalls in reverse
- Air Bag Deployment question???
- ATI Procharger (Opinions/experiences)
- Another EGR question
- HUH???
- oil filter
- Power loss #s w/ 35s and stock 3.55
- Z71 eater or eatee
- how much hp does the 96' 5.0 have?
- Can´t find vehicle's computer code
- Where are you getting 5W 20?
- Jacobs Ignitions, What do you know
- Command Start??
- Is there a Recall or TSB website for F150's? Especially, the oil leak problem!
- Opinion needed! Should i buy a f-150?
- Apples to Oranges - Old "Rat-Motor" to 5.4L
- what kind of gas mileage are you getting?
- Bad 5.4 FQR
- those with HD cooling or trailer pkg>>>
- Air Froce 1
- HELP - Major engine problem
- Moaning Sound
- 260HP 4.6L in an F-150?
- hp gain or hp loss
- 4.6 Growl
- ATI Procharger
- ? about F-150 chat
- Chip for 4:10gears NOT Superchip? dyno results
- Help with diagnostic code - EGR system
- What changed in the 2001 F150?
- 2001 XLT Supercab 4x4 on order!
- Anybody know hp/torque specs on 4.6, 5.4?
- fun had this past weekend
- loss of power while lugging
- EGR VALVE ?
- 36racin -- HELP with EGR ?
- More HP fom an i6
- kinda of an accident... what type of damage???
- Hey Guys!
- MSD Spark plug wires
- cold weather?
- Frozen gass pedal!
- Idle bounces between 600 - 700?
- "Bubbling" noises after shut off?
- Code Reader?
- Snow Problem
- 2001 PISTON SLAPPING
- 5.4 oil leak (Regular or Synthetic oil)
- Need New engine
- 2V and 4V 4.6L?
- Engine Miss and Check Engine Light.
- perfomance chip
- vacuum diagram
- Searching for RACECAR...got a question....
- gas brands
- low oil pressure(need help)
- 93 4.9 fuel pressure specs
- Is something wrong with my engine
- Expy v. Tahoe (off-topic, but...)(kinda long)
- snowplow
- My rough idle fixed
- Open AirFliters/Snowy areas
- Flushing engine before changing from DINO to SYNTHETIC
- 1989 F150 4X4 !! 5.0L power.
- Knock or Ping on Acceleration 1989 F150 4X4 !!
- What do you think?
- 4.6 spark plug change
- BOB
- NEED HELP WITH Posble. classact. LAWSUIT!!!
- Rough Idle
- Brand New FIPK for sale
- engine block heater
- Some Info About By-Pass Filtration
- A Rattle when on the Gas
- More power for cheap!?
- “Oxygenated Gasoline" (CRAP GAS)
- Which engine should I get?!!?!??!!?!
- Rebuilt engine ?'s
- Engine Swap ?
- Some answers about oil analysis
- K&N FIPK Kit for 2000 F150
- 4.6l Stalling
- Smell of hot antifreeze
- Computer relearning idle?
- Powerdyne SC and plugs!!!
- Engine running VERY cool
- BOSCH 4+ Spark plugs
- 5.4 head milling ?
- 1999 F-150 4.6 4x4
- Power hungry
- AIR tube
- so what's wrong with the 5.4L???
- What 93 Octane is the Best...
- 5.4 Head gasket replacement
- Exhausting Solved
- HELP- Need cam specs ASAP
- Where has my MPG gone?
- coolant flush in 4.6 v-8
- Detonation Follow-up
- F-150 Exploded views, Where??
- Engine Oil
- Flywheel HP vs Rearwheel HP?
- different oil
- Whistle-coke bottle sound fix!!!!
- Fram X2 Extended Guard Oil Filter
- Rough Running When Cold
- Went to trade for a new truck but....
- UPDATE: My Emissions Problem Solved...?
- Super Chip Installed!!!
- a few basic questions...
- Engine noise
- Slapper 5.4 replaced.....
- engine swap and fluids
- For all you cold weather drivers...
- Think i need a new alternator!?
- Amsoil 5w-30 in, 1-2 MPG +
- What fuel?
- Rear Wipers on Expedition!
- Should I persue this further???
- 1998 4.6 4X4 Bad Head Gasket
- oil smell / leak 5.4 engine
- Air Intake Hum
- Engine swap?
- Fuel Injectors - cleaning them
- Need ammo for service dept. on Wed.
- 2001 vibration 4.6
- Asoil 0W-30... WOW!
- Leaky power steering hose
- belt sqealing
- anyone want my 4.6 v8
- Need Code Scanner for A 2000 5.4 Triton
- What is "Rod Knock"?
- a/f and boost gauge hookup
- Redline fuel treatment
- Check Eng. Light On, but Still Runs Fine?
- Power Steering Leaking
- Shift Kits
- A-pillar / custom gauges
- Replacing Thermostat 4.6
- PowerAid or K&N F.I.P.K whistling?
- Service Engine light keeps coming on
- Coolant leak .
- bought a 5.4 what now? new computer,tranny?
- 2001 4.6 231hp????
- ? for andrew s
- Power pulley difference ?
- excuse my ignorance...
- Newbie looking for advice on F-150 purchase
- Jacobs Electronics: Anyone use their products?
- clicking
- Does anyone know???
- Milky / Cloudy Engine Oil
- 4.6L Valve Seals
- 4 wheelin question
- frequent dying of engine
- Anyone have info on the fuel system recall?
- 2001 Engine, Synthertic Oil? Filter?
- O2 Sensor reading "rich" on 4.9L
- Elec. Fan or Power pulleys?
- 5.4L Cold Start-up Noise
- idle problem
- Engine oil analysis?
- There has got to be an easier way...
- HELP!!! Emissions Problems!!!
- Cold Engine Start
- coolant how-to
- Don't you change it everytime?
- clanging noise
- traction
- 5.4 vs lightning engine
- Can You Say Bolt On Performance..!
- Extended Service Plan - 1Source Auto Warranty ??
- 4.6L Detonation Problem
- SIG TEST
- TURBOCHARGERS?!!
- more power and mileage
- Computer?
- Can someone tell me how to tighten my belt ??
- Synthetic Oil...
- Tranny's 4r70(reg f150)
- Interesting Web Site
- How do you Dyno An AWD Vehicle.
- 4.6 Engine Life?
- vibration problem
- Where can I get pulleys?
- REAL DYNO #'S FROM AFTERMARKET SUPERCHARGERS?
- AFTERMARKET FUEL PUMP?
- Can someone help with a 1984 f-150? Please?
- fuel injectors ?
- V6 V.S. V8
- 4.9L Running to lean.. Help!
- Gas Mileage Difference
- Holley Thunder Kit Super Charger (Anyone got one yet)
- Power Steering groan
- Switching to synthetic oil??
- Miss At Idle
- Supercharger, injectors, and mass air meter
- Oklahoma Guys- Buick VS. Ford......
- Cold air cover
- Question for anyone
- HELP!! Cardinal sin! Overfilled eng. oil
- Which company makes an intake kit with a new airbox?
- ESP Woes
- under drive pulleys
- ATI PROCHARGER kit for the 5.4 and 4.6
- spastic gas gauge
- POWERAID SPACER
- Check Engine Light always comes on
- best sites to sell a used rig?
- engine light blinking
- throttle body cleanup
- A retrospective
- Rattles after rebuild
- How much $$$ is a new belt
- HI ALL!! New to this board!!
- Shorty Headers
