excuse my ignorance...
I am just curious what, exactly, are the differences between the 5.4 (97-98) to the 5.4(99-00). Are the changes "simple"--just in case I want to make the changes?? I tried searches in this forum, but couldn't find the explanation I needed.....
On a side note: This site has been outstanding on solving issues and questions. Thanks, everyone
Bore and stroke for the 4.6 is 3.55 x 3.54 as for the 5.4 is 3.55 x 4.16
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications: K&N FIPK, Stepshield door sill protectors, Performance Accesories 3" body lift, Lift Lips, Gabriel Gas Ryder LT VST Shocks, Daystar front anti-sway bar polyurethane bushings and 35x12.5R16.5LT BFG All Terrain KO's on 16.5x9.75 American Eagle 589's.
Photos at: http://www.communicomgroup.com/jmtruck
How about the Coil-on-plug setup? Isn't that a 99+ (260HP version) feature?
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
My Home Page
New cams, 1mm larger exhaust valves, different head casting w/increased airflow, different intake manifold, no split intake plenum. This is what I read online???
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
Mobil 1, K&N oil filter, K&N F.I.P.K., Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s.
