frequent dying of engine
Old Nov 21, 2000 | 09:19 AM
tribefan's Avatar
Unhappy frequent dying of engine
We have been having problems with our 98 f150
dying. It is a stickshift and sometimes when we start it immediately dies. We try to drive it to the dealer about 10 miles away and it dies everytime you take your foot off the accelerator which is frequent living on winding roads and being a stick. I had to start it 28 times to drive 10 miles to dealer. Of course when it got there, it quit. They couldn't find anything wrong with it. It continues but sometimes does it after we get to a short destination and it sits for an hour. We start it and it does it again. It does go away sometimes quickly, sometimes not. Any suggestions would be helpful. I am a female and know nothing about this stuff but would like to be a little educated next time I take it in for this. Happy Thanksgiving!
Old Nov 21, 2000 | 09:26 AM
Dustoff's Avatar
Post
Check this link out for more info ----> https://www.f150online.com/f150board...ML/002701.html
Sounds like an idle control valve problem.
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with super engine cooling/Auxilary transmission cooling HD package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil, build 7/2000
Old Nov 21, 2000 | 10:11 AM
T Ellenberger's Avatar
Post
If all else fails leave it at the dealer overnight and let them start it when it is cold.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks
Old Nov 21, 2000 | 11:30 PM
tribefan's Avatar
Cool
We have left it at the dealer and of course it doesn't do it. Doesn't seem to be a cold problem. -4 with windchill today and it ran fine. Will check into the other suggestion. Thanks for the help.
