Coolant leak .
Old Nov 23, 2000 | 01:36 PM
Denaveechi's Avatar
Question Coolant leak .
I have a 97 with the 4.6 and I have smelled coolant lately. I noticed a small amount of antifreeze in the V of the engine under the intake manifold. Has anyone had a coolant leak in this location? Does anyone know what the fix would be? I have almost 49K on the odo.Please advise.
Thanks.
Dennis
Old Nov 23, 2000 | 04:57 PM
Conocoan's Avatar
Exclamation
Dennis,
You may have the same problem that I just experienced. My truck started running on 7 cylinders. When I told the mech. at the dealership he knew right off what the problem was which tells me it may be fairly common. Water dripping from the heater hose onto the #4 cylinder coil. This in turn shorted out the coil. The coil - labor cost $255. Luckly warranty covered it.
I had never noticed the leak but had just completed a 3 hour drive so it didn't take long to short out the coil.
Hope this helps
Mark
1999 F-250 LD 4x4 Lariat Supercab, 5.4 w/3.73 LS Limited Slip, Wedgewood Blue & Silver.
K&N FIPK
Flowmaster 40 Series
with duel stainless
tips in front of the
rear tire (see lightning)
Superchip
Line-x
Mobil One
Old Nov 23, 2000 | 04:58 PM
2001's Avatar
Wink
My BEST guess would be a coolant leak on the intake manifold...we call this gasket that seal's this location a "battle ship" gasket and is very common on the older vihicles to leak.
This is just MT BEST guess though....best thing to do is do a "REAL GOOD DETAILED" engine shampoo, let the truck idle for an hour or so while keeping an eye open for a leak in the location you had mentioned. Engines get nice and hot with good pressure on idle...and this is most likely when you will see this leak happen.
Old Nov 24, 2000 | 10:17 AM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Exclamation
I have a 98 with a 4.6.I have changed the
thermostat twice,on another chips' recommendation. Both times the lost coolant has run into the same area you are talking about. Check around the back
of the stat housing,you might have a bad
gasket or a hose clamp problem in that area. Look for any green or white discoloration around the stat housing also. good luck,,,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Euro tails(Altezza style)
Cobra 75WXST cb w/weather alert
[b]Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good]
Viper 500HF Security system
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
www.my-f150.com Still want to lift it,YESSS!
FENDER GUITARS,ROCK!!!
http://www.bigsandy.net
officialtomwaits.com
reverendhortonheat.com
WOW,what a cool site!
Old Nov 26, 2000 | 08:40 PM
Denaveechi's Avatar
Talking
Thanks for the replys, I have looked around the engine some more and I am pretty sure it is the manifold gasket leaking in the area underneath the thermostat housing.Does not appear to be thermostat gasket.Anyone have any idea what it would cost to have this fixed? Have not really noticed any drop in coolant in the overflow tank.
Dennis
