View Full Version : V8 Engines
- Where/what is the octance shorting bar?
- Crash! or other supercharger experts
- F-150 Diesel engine
- Smell raw fuel??
- ENGINE WONT START
- When will it stop!
- Which engine/truck should I buy?
- Where do i start
- Engine dies, need help.
- oil weight
- should i upgrade to 3.55 from my 3.31?
- 98 4.6 chk engine, rough, hesitation
- airaid intake system
- Engine stalling, need help
- Thanks F150online
- Engine Performance
- Who's the fastest Pro 5.0 racer in NMRA
- Poweraid Spacer Wanted
- Fuel problem, but where?
- out of the shop
- 5.4 -Wins best of breed AGAIN!!
- OIL USAGE -How much is Normal???
- Dodge Dakota's
- EGR Question
- Performance
- Supercharge A Harley Edition
- New FQR Installed - Report
- Horrible Idle surge on 2000 4.6 5 spd
- What kind of oil and filter???
- Hows this sound ? BRAND NEW 2000 F150 4x4 ext cab OffRoad,4.6 $26,000.00
- Milky oil filler cap
- Temp up, Oil pressure down!!!
- 2000 4.6...what is hp and torque?
- Buying a new engine!!?????!!!!????!!
- 5.4L horsepower
- need help w/ engine selection for new truck.
- Electric Fan ?!?
- Hows a 3:31 ratio for towing with a 4.6 Triton
- Dealer would't Put in Bosch +4's?
- Found a Cool Place with some great deals!
- ATTN: All FQR Cases
- how do you install the superchip?
- 5.4L using oil
- 82 mm mass air flow sensor..need input
- Questions for all that switched to synthetic.
- anyone tried the Superchip?
- Belt Squealing Noise
- will a mustang supercharger fit in an f150.
- fuel inertia switch
- Synthetic advantages?
- 4.2 trouble
- Buying 2001 F150,trading in 1999 F150 $7500.00 plus trade,? GOOD DEAL?
- The "Dead Horse" MAF sensor
- Bigger than std Oil Filter/Relocate oil filter system
- Change your diff fluid now!! DIRTY and nasty at just 12,000.
- New web page
- Borla's PowerSet for v-8 and v-10 Excursions
- Reset "check engine" light?
- 98 F150 4.6 L
- Electric Blower
- Ford Ranked #1 again!
- engines
- Weird hum from engine compartment.
- Gas Mileage Comparison
- Headers
- Synthetic ??'s
- GREAT DEAL ON 5.4 CRATE ENGINE AND "PI" HEADS!!
- coolant in the sparkplug cavity
- Oils
- Doesn't seem to be much room in Ford ext cabs compared to GM ??
- Newbie Here few ????
- Oil Light & Poss. Oil Loss?
- Can somebody record the sound of the piston slap?
- New Member: How is the 5.4L for towing 5,000 lbs (vs V10 or Powerstroke)
- Dying
- Idle Problems
- Resetting the computer
- 5.4 leaking head gasket
- motor flush in a can
- HORRIBLE gas mileage!
- Sticking throttle fixes
- Towing
- cam shaft positioner
- Possible help for Frustrated Ford owners!
- Gurgleing Noise ???????
- Low oil pressure when cold out?
- Well.. i did the airbox mod from the technical article section.
- I have 5.4L. can I test coils, if so how
- Truck Pull suggestions ???
- I NEED HELP
- zMax Additive
- Turbocharger Kit for 5.4 4wd Owners!!
- overdrive
- Two tone colors
- Amsoil bypass filter
- 4.6L coolant change/flush
- Warranties (Lincoln vs. Ford)
- airbox modifications
- fuel injection cleaning/knocking
- Mass Airflow Sensor and Throttle body spacer
- Is there a better Spark Plug
- Anyone else having problems with FQR Motors?
- 5.0L idle adjust valves
- Piston Slap in Older Engine
- Ford's customer service.................
- Rebuilding your F150 4.6L .......
- Warm up not necessary?
- Do the 4.6's have as many pass side oil leaks as the 5.4's ??
- Airbx Mods is the FIPK really the best?
- Question about older engines
- anyone have fabtech 3 1/2 lift kit with rs9000
- Second 4.2l engine trouble
- Rubbing noise...
- 4.6 pass. side oil leak?
- With this weather, the L is making mad power.
- What Happened?
- Saw something that made me sick today
- Valve Face Degree
- 1997 4.2 40k loosing heat ? HELP
- Anybody know how to get a shop manual?
- What was done about the oil leak/head gasket problem?
- Anyone had their slapper replaced w/no complaints??
- Frustrated ford owners
- What Happened?
- RE: '99-'01 replacement engines
- 4.6L Oil improvements
- A great big THANK YOU!!!!
- Coolant coming out tailpipe!!!
- Idle problems on my 91 F-150, 5.0
- Bigger Magnacharger numbers!!! Yeah!!!
- Supercharger and towing
- Engine revs itself up???
- SEAN HYLAND's SMOKING CRACK?
- Clean MAF sensor
- Sub zero temperature starts on 5.4
- Cold Air
- Check Engine Light
- Testing O2 sensors???
- F-150 in shop!
- Magnacharger Roll Call
- ENGINE OR TRANSMISION LEAK?
- Thanks
- For all who complain about Ford quality
- Information
- Tri-Synthetic
- Are you Charged?
- More HP?
- Question on K&N air filter.
- Better MPG
- 5.4 magnacharger kit
- anybody have alarm troubles?
- Downtown Tampa,Alarm troubles!
- Overheating?
- Looking for more towing power from 4.2?
- 4.6L Spark Plugs
- +13% more MPG using Premium?
- power cuts out at 95MPH
- For Sale: Oakley Replicas 22 styles *pics*
- head gasket (AGAIN)
- Engine number
- in-line spout connector
- Cleaning TB???
- HEY DUSTOFF
- Crash1
- Supercharger ?'s
- 1997 4.6 uses 1 quart oil every 3000 miles
- trans. vibrate/BAD gas milage???
- What are the most common problems with the 5,4 l? l engine
- AIRAID (will it pass inspection??)
- Low Emission Vechicle
- Knocking and pinging
- Head gasket leak - Going to dealership - Got any advice??
- comments on green and orange antifreeze
- white junk on oil filler cap
- engine flush?
- NO HEAT !!
- Possible Exhaust Leak???
- Truck is at the dealer status
- DIRECT HITS Ignition Upgrade?
- Filter Magnets
- Calculating gear ratio
- Triton Heads
- Running synthetic oil part time
- Success Stories
- Cost to remove cylinder head???
- Engine Belt Noise
- Am I getting Bad MPG In Florida Traffic???
- # of quarts it takes to fill up a 1997 5.4
- suggestion please
- 5.0 upgrade to 5.8
- Squeaky engine noise
- Piston Slapper diagnosis!!
- Why/When Did Oil Fliter Move
- A Little off topic
- Feels like Transmission is sliping when giving gas and shifting
- MERRY CHRISTMAS!!!!!
- Superchargers!!!
- do you change your own oil?
- Synthetic substitute for 5W-20 Oil
- True or False??? (5.4 rough idle)
- Can stop driving this thing. I'm addicted.
- Electric Fan
- 5.4 spark plugs installation
- Miles Per Tank?
- Magnacharger ?? again.....
- Reliability of Truck vs Car Survey (just curious)
- rough idle/engine miss
- New Vs. Old Engines
- Engine Size
- Oil Pressure gauge, problem or engine problem?
- charging system on 92 f-150
- Weight of 5.4 vs 4.6
- Engine Dress-up
- O2 Sensor bank - which is which?
- For those who had their head gaskets replaced. PLEASE REPLY HERE.
- Junk Ford Engines
- Alright, now i'm scared! f-150 are good but all these problems!
- Can I check and see if the odometer is legit?
- Whats with the oilfilter location.
- People who had engine replaced
- Airbox Question
- Ford V10
- Miracle oil / tranny / fuel additives...
- Rough engine @ 1400 RPM
- Redline fuel system cleaner,amazing!
- Synthetic oil
- OK, i'm new in here, can you all give me some tips & tricks for a little more HP???
- Exhaust Systems
- burnt antifreeze smell
- FQR Engines
- HP estimation
- FQB/FQR = ?
- Ford Extended Service Plans
- Miles per gallon, F-150 and Superduty's
- diesel or gas?
- Diesel in F-150?
- low temp thermostats
- 4.6L Oil Leak
- 2 problems
- Oil Filter Location
- K&N fipk Generation 2 part number
- ??'s for those with FQR engines or heads.
- When truck comes to a stop engine idles rought
- tornado intake spacer
- Fan problems
- TWO YEAR OLD VIBRATION
- Can someone clue me in on 2001 5.4L?
- 97 Expedition 5.4 stalls in reverse
- Air Bag Deployment question???
