View Full Version : V8 Engines
- 1997 f-150 5.4L problems?
- "Service Engine Soon" light
- Alternator Light at High RPM
- Loud Clicking Noise
- po171 / po174
- 5.4L revs at idle 700rpm to 900rpm
- 1997 F150 Coolant change
- US Oil Change Intervals & Weights???
- Does anyone experience loud injectors?
- 4.6L in '99 F-250
- Inertia
- Plugged Injector?
- Beating my head against the wall, need help!
- Radiator problems; questions!
- 4.9l missing at idle and low rpm
- Plug Wires bad in 15K??
- lower intake manifold torque specs
- Spark plug change on '98 4.6
- rebuild
- Any motor will do?
- 200,000 mile club
- Misfire
- Everything
- Everything
- 347 Stroker?
- Slight miss has me puzzled
- 4.6L 220HP or 4.6L 231HP...how to tell?
- Codes w/o a Code Reader?
- Found the source of my valve clacking...
- Truck will not start
- Best oil & filter???
- where to start looking?
- how to diagnose engine noise?
- rattling @ high rpms
- help with a truck
- removing plastic knob on column shift lever
- needs some headswap help asap!
- aftermarket gauges
- 4.6l Valve Seals
- 4.6l Piston Slap
- Dynoing a 4x4
- I6 to V8
- Thanks Ya'll
- Engine Compartment Gets Real Dirty Off-Road
- TDC on 99 4.2
- garage won't can't replace oxygen sensor
- 5.4L Performance
- Oil Info
- codes
- sometimes it starts.....
- Clunk then tapping noise on startup
- Genuine Ford Parts - Reputation????
- i need a motor
- Mr Bentwrench...Piston Slap Question
- Starter solenoid going bad????
- oil pressure sensor
- shaking
- stop crying!!!!!
- New to me F150
- 99 engine in 98 F150 HELP!!!!!!!!!!!!
- Check Engine Light???
- Can we prevent plug launch?
- Diesel engine...worth it?
- Looking at a 1999 F-150
- stalling
- Help! Vacuum tubing for "97 f150
- Any Upgrade ideas for a 4.2L EFI V6 Engine
- Need Ammo
- Engine Fire
- Oil Pressure
- engine cleaning tips?
- coolant leak misfire
- 1990 5.0 mis-fire
- special services messages your f-150 may have
- Shell Rotella T Synthetic 5-40 V.s. Mobil 1 & Castrol Syntec
- SES Consensus
- V8 question from a V6 guy???
- I.a.c. Valve ?!?!?!
- Maf
- fuel consumption
- warning signs for spark plug blow out?
- Please! need help! I can't cure!
- 4.6 stumbles
- Any tips on installing serpentine belt on 5.4L s'crew?
- Leaky timing chain cover
- Tapping noise - no load only
- electric fans in a full size
- Ruff Idle
- 5.4
- Next Upgrade??
- Starting problem/Engine runs rough at idle
- piston slap
- COP Check
- Which Engine to get?
- Cleaning fuel injectors?
- "cheap" horsepower
- Engine Starting
- new '04 fords vs. new chevy
- how good is the 4.6 V-8?
- "Piston Slap" could be oil filter?
- Help with 2000 F150 Power Steering Leak
- 2003 Screw says 5w20 can I use 5w30 ?
- Help!! Heater Hose Clamps
- 2001 Expedition Rough Idle
- 0171 0174 codes
- spark plugs
- Coil On Plug
- stalling out
- 1987 F150 engine problems?
- 5.4L slow?
- Ok I asked this before but what is that gas cap light on the dash of an '03 Screw
- hesitation issue...
- valves not closing w/ 1.72 svo roller rockers
- where do you get the new yellow/gold coolant and how often to change it
- great site! helped a lot with my 5.4
- Finally catching on...
- OBD code, misfire 6,7...lean on bank2??
- Which thermosta? 160 or 180?
- Blue Smoke
- fan belt slippage
- serp belt
- Poor runninn Chev
- Griffin - what Flex Fan did you go with?
- plug thread depth
- Intermittent failure to fire
- Mileage and a possible scam!
- Check engine...code P1451
- NGK Iridiums vs Stock Motorcraft on 2000 F150 5.4
- engine swap
- How much power?
- Triton 4.6 Litre Tune ups
- 4.6 ck eng light
- 2004 5.4 Sounds Like A Diesel
- Clickin' till it jumped time
- Heater trouble, very strange!!!
- NGK spark plugs?
- Synthetic Oil Suppliers: This may Amaze You
- 5.4 Clatters
- head threads
- 97 Alternator Amps?
- 4.2 and 4.6 3V
- need advice quickly - coils packs
- 2004 5.4 Engine
- Grinding Noise from engine in Drive
- Hesitation...?
- oil filter locations
- A/C vent run to air intake...cold air
- Ram air
- P1336 Code
- Will a 2003 Lightning Engine fit in a 2002 Harley?
- Stock HP and Torque
- Heavy grease on Air Filter
- 4.6 l horspower?
- 5.4 misfire
- SCAMMER ON CLASSIFIED Engines
- Scammer On Classified
- Kendall Motor Oil
- Won't start, please help
- 2004 F150 Throttle Body Problem
- Lighting Performance Fan Setup??
- which brand of spark plugs
- Altittude changes
- serpintine belt tensioner
- Pinging in a 97 4.6L that never pinged before!
- underdrive pulley's
- 0420 code?
- Sea Foam in Canada
- FI cleaners
- Gas cap light is on?
- Speedometer
- Truck won't start....HELP!!!
- Help! ive reached my wicks end with my truck!
- New here, finally got rid of the Dodge
- Would synthetic oil help this problem
- Radiator Hoses
- obd scanner
- RXP fuel additive
- Intake Manifold removal
- 300 head questions
- Engine missing bad under acceleration, need help.
- Head replacement killed truck! Help
- 1987 F-150 idling problems
- How long can it sit?
- Very rough running! Please help!
- I've got a plug behind my front bumper
- California Emissions
- WOW Edelbrock IAS Performers
- Lost my power steering, any info on it, anyone?
- More Powerful Ignition Coil
- throttle body vs. mileage
- Idle Problems
- cylinder 8 misfiring
- 4.6 to 5.4 engine swap
- Mileage, 5.4L V8 with a Northstar pop-up camper
- Stock Cam Specs
- Engine Vibration upon acceleration
- Not an engine question... but..
- PCM Question
- foaming oil
- Oil Pressure on Odometer
- Amsoil Oil
- Engine tick help
- warranty void/oil change
- Stuck Spark Plug
- Another K&N Story
- Need Help!!!
- Air intake part ?
- I need help ID an engine component (Pic Inside)
- Misfire 5.4
- 2 types of 4.6?
- No fuel in fuel rail. 89 F150, 302
- Amsoil PI improver
- Where is the EVAP sys. at?
- Can anyone explain this?
- HELP! Idle Problem and Noise
- Help...Irritating Whine/Hum/Whistle or Something Noise
- Ticking noise
- 5.4 flareside reg cab, havent seen another
- Seafoam Users: Read This !!
- Heater Core Replacement
- why the diff in torque and hp from 2003 to 2004 ??
- 16 mpg
- f150 a piece of crap
- 16 mpg
- Engine Light Fix
- Need help!
- 13 mpg??? What's the deal?
- Factory Service Manual-find
- Factory Service MAnuals-FIND
- cubic inhes to hp.
- engine swap
- 99 5.4L start up knocking?
- Check engine light
- Engine failsafe mode
- Revs goin crazy!?!?!?!?
- Denso Spark Plugs!
- Fuel injector/regulator knock on V6?
- Please help on an 85 Ranger!
- Truck Mods
- tires
- Straight Scoop on Fuel Mileage: '04 F150 w/5.3
- Advise Needed. Emmissions or Electrical?
- free code reader in Toronto?
- 89 F150 Front Tank Doesn't Work
- Should I feel bad?
- Rod Bearing Going
- 2003 4.6 Squeek?
- Blown Head Gasket ? Please Help
