More Powerful Ignition Coil
Old Mar 17, 2004 | 06:59 PM
UrbanCowboy's Avatar
If I get an aftermarket ignition coil with a higher output, run a bigger gap on the spark plugs, I should get more power per my understanding. But what about gas mileage? Would my mileage go down or is the improved power just a result of a cleaner fuel burn? thanks
Old Mar 17, 2004 | 09:58 PM
Pickup Man's Avatar
You would think that it would improve mileage, but I don't know. Anyone?
Old Mar 17, 2004 | 10:13 PM
Home skillet's Avatar
Due to the laws of physics, a coil will only put out enough voltage to jump the spark plug gap. The stock coil is all you need.
A bigger spark does not necessarily mean more power.
There could be a delay in when the plug fires in relation to the compression stroke. Would be the same issue with running high octane fuel.
