Loud Clicking Noise
Loud Clicking Noise
I've noticed a loud clicking noise, like a solenoid coming on and turning off; it idles up on the click and then idles down when click noise sounds again. Almost sounds like when A/C comes on, but no A/C at 40 degrees. Could it be the IAC - it's only five months old.
Thanks!
Thanks!
Brucescrew...
The AC will cycle the compressor even at low temps even if the system is not physically turned on. It's designed to do this to lubricate seals and circulate refridgerant. The system is governed by an ambiant temp switch which completely disables the AC only during extreme low outside temps. The clicking is your AC compressor clutch engaging normally and the engine control module (ECM) aka computer, revs up the engine to compensate for the added load required to run the system. I'm not AC certified but I have been trained and I read alot. I hope this helps.
Chevyssuck
Chevyssuck
