0171 0174 codes
Old Mar 27, 2004 | 12:00 PM
horsefli's Avatar
0171 0174 codes
lean on bank 1&2 any suggestions i was thinking fuel filter or plugs but this all came about at one time. thanks for any suggetsions
Old Mar 27, 2004 | 12:10 PM
01screw's Avatar
You're probably right, I'd start with the filter.
Old Mar 27, 2004 | 06:58 PM
Jag's Avatar
Jag
Couple of other possibilities:
A dirty MAS or a vacuum leak (introducing unmeasured air into the intake manifold) can set these codes.
Old Mar 27, 2004 | 10:09 PM
projectSHO89's Avatar
A SEARCH on "P0171 P0174" will show you the most common reason for this very common and FAQ.
Steve
Old Mar 27, 2004 | 10:52 PM
olgzr's Avatar
I got those codes when I left the oil cap off after changing the oil. Reinstalling the cap and reseting the computer cured it. The codes were because of the extra air going through the pvc valve due to the missing cap.
Old Mar 28, 2004 | 04:36 PM
guzman_marcos's Avatar
0171,0174
Change your pcv valve with hose; you have a cracked elbow the one near the wall.
Suerte!
Marcos
Santo Domingo
Old Mar 28, 2004 | 07:34 PM
horsefli's Avatar
sir guzman
you are correct exact right hose,i did do a search on those codes after i posted and got some hints thanks for the input. damn special hose though ford here i come.
Old Mar 29, 2004 | 04:28 PM
Damm!
I wish I had the same luck with my air conditioner!
I have a leak, but can't find it
