head threads
Old Mar 23, 2004 | 09:19 PM
brahmus's Avatar
head threads
does anyone know if it is possible to add more threads to the stock heads before the spark plugs blow out. oh 99 5.4. i have the heads off for a forged build up so now would be the time. will this have to be a machine shop deal or can it be a do it youselfer?
Old Mar 23, 2004 | 11:40 PM
svt_sc_f150's Avatar
I'm pretty sure you can install threaded inserts that have more threads. Check with Fox Lake, I know they install inserts in the heads that they build. Just a thought.
Old Mar 24, 2004 | 12:32 AM
lees99f150's Avatar
use the time-sert inserts. i repaired a blown plug with one a friend of the family works on a NHRA top fuel team building engines and he says they install inserts on their aluminun heads for the plugs. the insert has a lot more threads biting into the aluminum the just a plug. just my $0.02
Old Mar 24, 2004 | 01:53 AM
Intel486's Avatar
Where in Louisiana are you? I'm in Baton Rouge @ LSU
Check with Sean Hyland. They might be able to tell you what you can do. He's been fiddling with the modular motors since they came out and has 4.6l motors doing 1500hp. He's got to do something to keep those plugs from blowing out. http://www.seanhylandmotorsport.com/
Old Mar 24, 2004 | 10:30 AM
brahmus's Avatar
Intel,
Lafayette UL Mechanical Engineering. thanks guys i'll look more into it. do you think i should do them all now before i start running about 14-16lbs of boost from a supercharger or wait until they blow?
Old Mar 24, 2004 | 10:42 AM
(o)here(o)'s Avatar
Originally posted by brahmus
Intel,
I'd do them now. Each insert is $7, the install kit is $125. Well worth the piece of mind, IMO.
Old Mar 24, 2004 | 10:53 AM
brahmus's Avatar
(0)here(o),
where do you get those prices and where can you buy that kit?
