View Full Version : V8 Engines
- 2002 5.4 Rough Idle
- Misfire or Inject failing...
- Error Code Po401
- engine dies when warm?
- tb/tb elbow port & polish
- 97 4.6 misfire problems
- Push or Pull Air
- 1994 f150 maf conversion question
- Lightning Supercharger
- mass air cleaning/gutting
- anyone who works for a ford parts dept?
- Problem finding air filter
- Blown Fuse?????
- 5.4 oil capacity w/out filter change?
- Loss of Power
- Running rough? or resonance?
- whats the hp of a 78 f150
- Sooty Exhaust
- Idles high
- coolant capacity? 4.6L
- Loss of Power over 70
- 4.6l Plug Replacement - Are You Kidding?
- I conceded Defeat
- Autolite Double Platinums vs. OEM Motorcraft
- 04 w/ 4.6L or 03 w/ 5.4L?
- Oil capacity for 4.6L?
- 97 351w Question
- Help, Triton blowed up
- After market throttle body choice
- Loss of power
- cylinder #6
- 97 4.2 engine prob
- stutter and surging
- Starting problem
- air filters
- 4.6L spark plug replacement
- Oil filter question
- 5.4 vs. 5.8
- 98 XLT Cab removal
- plugs and wires
- Disconnnect battery
- Coolant Gauge
- 5.4 75 mm throttle body owners
- two coolers?
- engine swap
- Performance Intakes?
- lowering a 4X4, need input
- The 'ole ERG thing again..
- Overheating
- 2000 Expy - What is the stock HP and TQ rating?
- valve noise?
- Check engine light on but no codes
- 1998 F150 Starting Problems
- Truck won't start
- Denso Iridium spark gap?
- too lean!!
- 4.6 oddity
- ** Ignition Coil Keeps Going Out, What Can I Do **
- 4x4 club
- strange engine noise
- Rattling at low idle
- EGR Error Code, O2 Sensors & Mileage
- EGR VACCUUM ASSEMBLY 98 4x4 5.4l
- What to look for in a used truck
- How many miles is too many miles?
- Help, Rockers loose after head job
- Temp Control
- engine stalling
- White smoke at start up
- performance exhaust headers
- How to get codes and what do they mean
- overheating
- 4.6l spark knock
- Please Help!! Motor Swap Questions
- Anyone have a picture of the iac on a 5.4
- Will not start
- Water Pump Blues
- Engine Swap
- Denso Iridium IT16 spark plugs
- MAF change
- Unusual engine noise
- Fuel pump self test connector location?
- Airaid Install...What should the next mod be
- Rear diff. or E-brake levers squeaking need your thoughts????
- Suggestion for high mileage 4.6
- big six exhaust
- Oxygen Sensor error code...Help? Po153
- '96 Engine Died Suddenly
- code 172
- STROKE vs Durafart I mean max LOL
- nothing at all
- Need timing for 1989 f150 302 w/ac
- Possible ignition problem?
- Vacuum Leak?
- Ford F-150 Problems
- Oil- synthetic or dino?
- Code 171 and 174..???
- 95 F150 Fuel Pump Replacement
- new 5.4L heads
- Bad Maf, Bad Maf
- engine started missing
- Engine Help Please---DPFE out Code 401
- Oil in antifreeze
- Starting problems
- Hydro Lock?
- Anyone use...
- Please HELP!
- Truck just dies or is on its last leg
- How much HP 2001 5.4?
- Mpg
- yea
- 4.6 spark plug wire damage
- added Horse power
- TSB and recall info? General recalls?
- OIl pump draining pan dry
- maf and o2
- 2000 5.4 intake query
- Coil Packs
- k&n backfire?
- high idle, smoke at start up
- 4.6 or 5.4
- Question About Leaving Truck Sit
- i cannot find my spark plugs and wires
- Egr Sos
- ? about IAC cleaning
- 97 4.6 head gasket leak? Is it common for 97? Should I bother?
- 2004 5.4
- Help Please
- 4.9 I6 freeze plugs {need help quick)
- what are the best spark plugs?
- My 5.4 EGR trouble/engine bucking & Solution
- Tune Up Suggestions
- Octane and MPG
- 88 F-150 Not starting, can't figure it ou
- need help installing a shift light
- Check engine light PO401
- remote oil filter hose leak
- Airforce One Help Please
- Does Restore enigine restorer work?
- 5.4 3v noisy?
- Spark Plugs
- what in the world is a turbonator?
- Replacing a Starter
- Some new Motor pics
- Be Warned, Stay Away From Jacobs/mr. Gasket Products
- Accel coil packs, worth the money!
- K&N Air Filter
- fluid flush?
- Coolant leak on upper intake - 96 F150 5.0L
- A/c And Rough Idle
- Do I really have to change spark plugs at 100,000 miles?
- Low oil pressure in 97 F150 4.6
- 1984 F150 5.0??
- Can I put a different motor in my 97?
- Sick little 4.6 (Running Lean)
- 1715 microtuner
- Egr?
- leak or not a leak??
- codes
- Another tick in a 4.6
- 97 4.2L Should he buy it?
- Oil pressure sensor
- 98 4.6---aluminum or cast iron
- Pls help identify this motor
- SCrew is blowing white smoke!
- '98 F150 with 5.4 running rough at idle, and dies, check engine
- P0305 and P0174 Errors on 98 4.6
- Loosing power in 90+ degree temps
- Engine Rebuild price
- PATS ignition?
- '02 F-350 wiring in a '97 F-150
- F150 5.0 liter cap & rotor replacement
- average 11.3 miles (most city driving)
- Remote Oil filter Adapter
- Losin oil pressure w/ a/c on at idle
- 300hp engine swap
- 92 F150 Electrical?
- Truck Won't Start
- warranty almost over
- vacuum leaks
- Sporadic White Smoke at Exhaust
- Proactive Maintenance
- Sounds like dry engine on startup
- f-150 lightning
- someone must have the key!
- '97 f150 4.6 head leak
- rough idle 04 f150 heritage
- What all is involved in a 4.2 Tune Up?
- Need a new 5.4
- 5.4 performance mods?
- 1997 4.2... Need I say more?
- egr restrictor plate
- Engine swap problems
- 5.0 Missing Out When Hot
- Coil Packs on Fords....Insight wanted
- 4.6 to 5.4
- Knock Knock??
- The familiar 1997 4.2 leak
- 4.6 engine cut out
- 5.4 head leak!
- f150 sUPER CREW
- towing
- Engine light on/off HELP
- I'm pretty much done with Ford Trucks.
- spark plug change
- Need Some Engine Help
- HELP needed: '01 SCab 4x4 XLT with 4.6L is a DOG!
- Fuel Filter Change...a poem
- 1st time Seafoam user
- Starter stuck
- Crate engines for 97 F150
- Make my truck haul ass
- Where can I get SeaFoam in Canada?
- Gem Module 97 F150
- E-fans or Superchip
- Aftermarket camshafts
- underdrive pulleys
- 7.5l
- Buy 97' 5.4L with 200k miles on for $4k?
- Switching FROM 10W30
- Won't idle, need help fast!
- Gage lights
- Mods to Put on 1990 f-150 xlt lariat
- oil in intake
- Returning intake to stock, need help
- Oil Light Comes On, and Temp Gauge Goes HOT...HELP!!
- quick hp gains to 5.4
- poor man intake ??
- 2004 performance chips
- alternator question
- 2001 5.4
- Please help me diagnose my sluggish F150
- 5.0 check engine code (0401)
- 2004 F150... have a Diagnostic Mode?
- E-Fans, Again
- K&N Airfilter Cleaning time
- Air Intake
- Towing capacity
- removing circulating hose
- ROugh idle
- 5.4 2001
- Need Obsolete or Hard to Find Ford Parts?
- 5.4 idle problem?
- any 200k+ miles on 5.4 motors?
- where does ford get its reman engines?
- reflash
- bored 4.6
- 1987 F150 351W. won't start
