spark plugs
Old Mar 27, 2004 | 08:47 AM
just4x4fun's Avatar
spark plugs
the plugs on the passenger side were carboned up (black)
the plugs on the driverside looked normal
01 expy 5.4 4x4 no codes
Old Mar 31, 2004 | 11:29 AM
Throttle's Avatar
You are running rich on bank two, but not enough to throw a code. Make sure your air filter is service regularly and clean the MAF sensor. Try running a fuel/combustion chamber cleaner through it. You want to take steps to correct it otherwise you run the risk of damaging your catalytic converter on bank two.
Old Apr 1, 2004 | 09:58 AM
Intel486's Avatar
Think the o2 sensors also control that a/f ratio. Might want to see what the ones on that side look like and possibly change them out.
