PDA
View Full Version : V8 Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 [118] 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149
  1. What is "Failsafe Cooling System"
  2. Ok guys this decision is killing me,new Chevy or new F150?
  3. coolant leak?
  4. Broken Studs on Wheel
  5. computer codes
  6. need info on rough startup,PLEASE!!
  7. Just cleaned my MAF, question now.
  8. Computer Chip
  9. Do thunderbirds have distributors??
  10. New Guy, I need some Q/A....
  11. new '03 engine question
  12. kinda cool
  13. Spark Plugs. Which are best?
  14. '97 F-150 4.6
  15. oxy sensor testing?
  16. Muddy Engine/Slight Hesitation
  17. spark plug trouble
  18. power steering??
  19. Wierd Smell
  20. Who has N20
  21. How hard to change plugs in 1999 5.4 expedition?
  22. Starting problems!
  23. I need help...quick
  24. Start Problem
  25. Plus 4's
  26. Speed sensor....where is it help please
  27. Pinging 5.4
  28. Yikes! 500.00 for a tuneup?
  29. 11.8 Wtf???
  30. Adding a REAL Oil Pressue gauge, drain first?
  31. crazy oil pressure gauge
  32. cooling system / heater core
  33. Fuel Additives for carbon removal?
  34. Ebay Repair CD's
  35. '03 Power Steering Noise
  36. Truck Problem
  37. 03 motors/tranny's
  38. flashing check engine light
  39. Mobil One 0w-20 Synthetic is on the way
  40. P0153 & P1151 fault codes
  41. 95 f-150 specs
  42. Burning Oil?
  43. 2002 5.4L cold engine knock
  44. Any 6.8L Triton V10 owners out there?
  45. Help! What is this sound?
  46. Can omission of di-electric grease cause rough idle?
  47. Fuel Filter
  48. New Torqshift trans info
  49. PING or KNOCK.
  50. New Triton 3 Valve Info
  51. First Review of New Power Stroke / Power Tor
  52. Water on my dipstick???
  53. Formal Intro (I'm a newbie)
  54. Never Buy A Dead Mans Truck!
  55. If you 4.6L is pinging, make sure you check this out.
  56. need fuel filter help
  57. Thought I'd ask!
  58. help with blown sparkplugs?
  59. What type of P/S fluid?
  60. Engine noise gone
  61. inserts or helicoils for heads?
  62. Piston slap again. Need help.
  63. Buying A New F150
  64. replaced head gaskets again
  65. Why Does This Thing Run Out Of Gas On Hills!?!?
  66. Ford Baby Diesel aborted...
  67. P0402 EGR - installation question
  68. Any maintenance things I should do now?
  69. Click...Click...BOOM?
  70. Is This Anal Retentive.......
  71. Remote oil filter problem?
  72. I'm about to do a tune-up on my new truck for the first time....
  73. Fuel filter replacement
  74. engine trouble, got codes
  75. 1997 f150 won't start, just clicks
  76. more power
  77. IAC or TPS
  78. Weird noise in cabin
  79. SVT models
  80. Modding drop-in K&N...
  81. plug killer
  82. throttlebody install
  83. Electric Fans Question
  84. Air Box Silencer Removal?
  85. Engine Stutter, Power loss
  86. Rough Idle?
  87. V6 to V8 swap?
  88. leaking sending unit?
  89. It doesn't sound good for the V-6 diesel!
  90. Amoco or Texaco? (P66 or Conoco?)
  91. 120,000 miles, any advice?
  92. returnless fuel systems.
  93. 7.3 & 6.0 litre TD units
  94. O2 sensor location?
  95. Cheapest place to get WMS Velocity Tube or similar?
  96. Motorcraft 5W-20?
  97. 5.4 Internals..
  98. This clicking sound is pi$$ing me off!
  99. power steering
  100. K&N or FL820S ???
  101. What is the proper idle rpms in gear?
  102. anyone getting rid of stock airbox ??
  103. What's your average speed?
  104. How's your 5.4 doing?
  105. Block Heaters
  106. please help clarify head gasket on 5.4
  107. Loss of power and acceleration
  108. 4.6 plug change
  109. engine dies
  110. 1995 5.8 questions
  111. Not a K&N or Lucas problem
  112. Ebay intake with stock MAF housing & airbox?
  113. Engine Code PO455
  114. Head Warp?
  115. Increase Gas Mileage/HP
  116. High idle after decel w/no throttle movement
  117. Throttle Body Cleaner
  118. What is the lowest temperature thermostat I can safely use?
  119. cold air intake sensor? (on ebay)
  120. What do you guys think of Trans Co
  121. '99 F150 5.4 Service Engine Soon
  122. Belt chirp on first start
  123. L motor
  124. 1990 5.8 L for towing
  125. Ebay intake kit question?
  126. 1986 water pump schematic
  127. Where to get intake tube? Vaccume hose question?
  128. How many quarts?
  129. Fuel Master Installation
  130. Engine Power Curve for 1990 5.0L V-8
  131. Not Happy With Chip
  132. No Tire Spin
  133. PI heads Swap
  134. Any Other Folks Happy with Their 4.6L?
  135. Dyno testing in San Diego, CA.
  136. 1999 F-150 5.4
  137. MAF Question
  138. rev limiter
  139. EGR (EVR) Solenoid??
  140. whistling intake
  141. Superchip ??????
  142. Valvetrain problems?
  143. misfire
  144. coil packs
  145. error code 0174
  146. Decarboning engine ??
  147. Lack of 60mph power 4.6
  148. how do Iclean MAF sensor?
  149. Mobil 1 anti-return valve problem
  150. Ok guys,Screw or S/C,Pors and cons please!
  151. Help . . . truck falling apart?
  152. Odo DTC code
  153. Loss of power in Higher Gears
  154. Good ODBII Scanner???
  155. Fuel Pump
  156. On The Seventh Day!
  157. DAMMIT i got pulled over AGAIN !!!!!!!
  158. Burping??????
  159. Installing #8 coil Pack???
  160. Ignition Coil/ Idle Air Control Valve
  161. Throttle body spacers any good?
  162. rotten gas mileage
  163. Markmizzou-------->
  164. Need info on 1977 4.2 engine recall!
  165. Engine Overheating - HELP!!!
  166. V8 difficulties
  167. P1120 TPS Out Of Range Low
  168. 5.4 dohc swap
  169. Went over 5,000 mi. on oil change...
  170. 5.4L Spark Plug change.
  171. MPG Question
  172. Difference between 97/98 & 99- 5.4L
  173. Check Engine Code PO455
  174. I believe I have Pistion Slap
  175. What to do at 30,000 mi. service?
  176. i want my cel back!
  177. No Check Engine Light ????????
  178. Check Engine: insufficient EGR flow
  179. can oxygen sensor be cleaned?
  180. Dirty IAC at 32K?
  181. Air Box Replacement on 2001 Screw
  182. Strokers for Towing
  183. Brake pads.... which do you use?
  184. 97 4.6 misses at idle and in the lower RPM range
  185. Won't shift out of PARK
  186. Oil Pressure
  187. rough idle at start up?
  188. EGR code error---Bad Gas Mileage?
  189. Oil on the spark plug, wire,
  190. Oil Filter location change
  191. 1996 Dies after sitting for a few days
  192. How do you reset the computer?
  193. Speaking of gimmicks check this out
  194. difference between 2000 and 2002 throttle body?
  195. fast idle?
  196. Serpentine Belt & Tensioner ????
  197. F150 7700
  198. check engine lite..EGR Code
  199. steering noise
  200. Have clunking/dieseling sound????
  201. harley truck stalling
  202. Idle Question
  203. Engine wines in morning or when engine is cold?
  204. bad speedometer
  205. Engine/Exhaust? Noise @ Start-up
  206. My truck is Sick
  207. My 5.4 sounds like a diesel in the am!
  208. High idle
  209. thermostat questions
  210. Link to a guy who really knows his stuff
  211. Engine runs rough after sitting a few days
  212. tornado air intake
  213. MPG, computer/exhaust vs. heavy foot
  214. miss at about 3k
  215. Check Engine Light
  216. Royal Purple
  217. Spark plug changing emergancy!
  218. Billet Grille Need Help or Instructions Please!!!!!
  219. Install ?? for Plugs and Coil Packs
  220. deisel 150???
  221. Water in cylinder 8?
  222. Engine misfire on 4.6l
  223. Airbag light?
  224. frustrating 92 5.8 rough start
  225. Mustang engine: easy swap????
  226. Bad coil pack?
  227. abs light is flashing and shifter is stuck
  228. I used to think the 5.4l was fast...
  229. Knocking 4.2
  230. Got smoked by a ricer
  231. How much do you think its worth?
  232. Hesitation during hard acceration
  233. Beware, No Warranty
  234. Mobil Supersynthetic 0w30?
  235. Head Gasket Leak
  236. What Three Gauges Would You Choose?
  237. Handheld Superchips Tuner- YAHOOO!
  238. Heater Core or Head Gasket?
  239. Truck is in for the head gasket again
  240. Need help on mod?
  241. Radiator Hoses - HELP!!!!
  242. Which Engine
  243. 92 F150 Engine Swap
  244. 92 F150 throttle cable adjustment
  245. Airbag Code Flashing "32", Need Help
  246. 6.8L V-10 in a Expedition
  247. Any suggestions for auxillary oil filters?
  248. what is that steel tube
  249. Air Filters
  250. Help with Superchip
