Hesitation during hard acceration
Hesitation during hard acceleration
...i have checked everything i can think of......the fuel filter is new, the oil has been changed and the plugs are still good..........what have i misssed......around 3000-3500 rpm's the engine wants to studder then it "catches" itself and it kicks back in.....but when i am "normal driving" it does not do this .could it be the fuel pump not giving the engine what it needs during the "peak demand" of fuel......please help.....thanx Pete
Wouldn't sweat ot it but I would still have to say it's in the plugs or wires somewhere. It seems 90% of the time when someone on here as a studder/shudder issue it's the dang ignition system.
Truthfully it could be anywhere from bad plugs/wires, to a sensor, to injectors/ fuel system, to programming.
Try running a bottle of Chevron Techron for a tank or two first.
Are you getting a check engine light? About 4 months ago I was getting the hesitation during acceleration along with the CEL and a code 0304 (Cylinder 4 misfire). Changed the plugs and wires and I haven't gotten another CEL but the hesitation is back. Is there anything that can cause this symptom without setting the CEL? I would think that any ignition issue (plugs, wire, coil packs) would set the CEL.
My hesitation/stuttering only occurs when cruising above about 40 and I try to accelerate lightly (if I stomp on it, it downshifts and accelerates fine, or at least better).
'98 F150, 4.6L, 59,000 miles, all stock.
gdolson
What you describe is classic systems of the 4.6 misfiring. They can and do misfire without setting a CEL. Mine did it for 3 months and never even set so much as a pending code that there was a misfire. At 40-50 mph and light accel it would shudder and I even thought it was a tranny problem for a while. Only after a full diagnostic scan did I find that the plugs were at fault. I also had a premature failure of my xact plug wires, they lasted about 8m months and 22K miles.
If I were you I would check to make sure all the plug wire boots are seated firmly and have plenty of grease on them, also at night watch for arcing (a mist of water can help). For a shot in the dark you could try plugs and wires again. You should still have a warranty on the wires so theres another free set and just buy new plugs. Might cost you $40 tops. Other than that I do not know- fuel problem?
wyoming
I'm not sure on yours. Could be in the ignition. Anyone else have advice?
wyoming
