View Full Version : V8 Engines
- If you had a 97 that needed a new engine...
- Name a good message board for the powerstroke diesel
- harley davidson
- If not K&N - what paper filter ?
- Engine Light On
- I feel so dumb..where are the spark plugs?!?
- Airforce 1
- How fast can the F150 V8 go?
- enige hard to start
- Help! bad a/c evaporator and filter
- 5.4 engine hesitating below 2K RPM
- Throttle body
- dual function res.?
- engine hard to start
- Under drive pulleys pros/cons
- Fried cylinder coil
- Ever dropped anything in the intake area?
- Oil ?
- Intakes
- Anything to worry about?
- lack of fuel? no CEL
- Odometer working intermitantly
- help! my a/c is blowing hot air what should I check?
- 2000 5.4 Egr
- Heater Core Inlet Hose
- truck is bucking & missing
- PO430, Catalyst Efficiency Below Threshold? What to do?
- Exhaust Valve questions- Burning oil
- Dropping K&N, going back to paper!
- Inceficiant EGR flow (please help)
- 97 Oil Filter Re-Location
- 4.6 possible vacuum leak. . .
- Fuel Pressure
- throttle body spacers
- Charge Idiot light coming on
- 98 OBDII Codes- Help
- Indications to Clean Oil-Based Air Filters
- MAF Sensor
- engine problem? tranny problem?
- Air Intake, which one?
- HELP coil pack specs
- How much is too much (a leak)?
- Upgrading ingition 2.9L 177..Where to order parts?
- 98 heads
- Haynes, Chilton, CD, any manual will do for my 03
- Fuel pump replacement
- Mobil 1 filter
- 4.7L vs. 5.4L V-8
- mpg for a diseal
- Are there any tricks to removing valve stem seals?
- How often do you clean your K&N . . .
- O2 sensors
- Deja vu? IAC Valve out again?
- Engine
- Hypertech's Power Programmer III - Worth The Money?
- Ok guys, one more time with a DTC PO136
- Question about coilpacks
- Sputerring at Acceleration
- This is getting ridiculous
- Profile Ignition Pick-up (PIP) HELP
- CES Light but no Signs
- supercharger
- 4.6L F150 Sputtering on Acceleration
- Air/Fuel Gauge?????
- how to test ignition coils?
- plugs?????
- Powermaster 200 amp alternators
- 12.3 mpg on my 4.6L?
- torque specs for ASP pulleys
- 4.6 Misfiring/stumbling bad mpg
- Mercury Engine Swap
- Stuck & Need Your Help!!
- Mobil 1 vs. Motorcraft question
- missing 97 4.6
- Service engine light on after servicing filter
- Converting Engine
- Paper air filter v. oiled for intake system
- Bronco II/Ranger experts help please
- Please Help!!!!!
- 1 more question about plugs
- 4.6 Bashing
- 3 Valve 4.6 Liter Coming
- Apologetic GM tries to sell new-found quality
- 1994 f-150 engine surgeing
- P0306 errors and misfiring - Help
- Opinions
- Is an Overhaul over budget?
- EGR Valve
- Glycol in oil - how many miles left?
- Please Help! Coolant leak!!
- A New Engine?
- So many mods, please help prioritize!
- Mac3501??
- Dealer assistance on a P.O.S.
- air intake, hmm, idea!
- Engine experts, please help, please!
- injector ticking?
- What is this wire??
- No oil pressure
- blower
- Blue smoke on startup
- Coolant Leak
- Engine miss
- Need some help troubleshooting.
- Engine Vac??
- Not an exhaust leak.... What could it be??
- K&N= Service Engine Light?
- No Start???
- Need help diagnosing miss
- Engine ID
- Is this gas mileage jump possible?
- MAF Sensor Positioning
- Ditch my pinging 4.6L '98 & get the '04?????????
- What now, I have engine codes, I dunno what to do!?!?
- Replacing my spark plugs
- Sorry - Another Synthetic Oil ?
- 91f-150 run rough
- Can anyone help me find a Camry Forum as good as this one?
- engine misses/blinking engine light
- Turns over...won't start...HELP!
- Calculation of MPG
- What not to buy.
- Top Speed Limiter
- High idle at start up?5.4
- Rear End Noise & Vibration
- I'm confused! Help, please!
- Update:
- underdrive pix?
- update
- Problems starting/Idling
- Rattling, Ticking--What is this noise!!!?
- 5.4l misfire at 1500rpm's
- Airraid
- update
- injector question
- constant steering noise
- Thanks alot. Seriously this time.
- Engine Running Rough--Any suggetstions
- 2003 5.4 Engine Oil Coolers
- mxracer514
- What is your payment??
- Coolant Leak ***HELP***
- Thanks for nothing MF's
- Help w/ possible problems
- valve spring on 4.6
- Air filter
- engine swap
- Oil Leak
- Question about changing the sparkplugs
- Fitst Mods. What Should I Do?
- Trouble Cranking
- I need everyone's help!!!!!
- E4OD Problem...Not shifting into gear!
- Gutless Wonder!!!!
- How in the @#%@ do I get this out??!!
- 24# injectors
- Gas mileage???
- Rattling Noise
- PCV hose HELP!
- no spark
- Do i need a rebuilt engine? New tranny too?!?
- 5.0 timing for street
- 1st oil change done?
- How hard to change head gasket on 4.6?
- Need help locating a tool
- Vibration
- Mustang 4.6 vs F150 4.6
- Failed to Start
- Engine surging
- Engine specs
- 2nd best dino oil?
- Engine died
- Help, Dropped Bolt
- Head gasket leak,door crack & Cab paint cracking!
- Intake Systems
- mass airflow sensor-part#
- need v-8
- Best Mechanic for Mods in NC
- 03 Expy: Oil temps and Hard use?
- V12
- Engine specs
- Head gasket Leak
- embarrased to ask this but..
- Yet another idle problem
- WOT hesitating question
- Engine stalls
- question for LABNERD
- First post,changed everything & still misses on #2
- codes P0171,P0174
- Need Help!!! Dtc P0300, 0304
- Self-repairing truck?
- oil change
- Code Po401
- 280 miles per tank of gas
- Truck is skipping
- 2 stroke gas in truck
- High Pitched Whine
- Is straight weight oil, okay?
- 4x4 Schematic
- I Got One For All You Master Techs
- Doggy 5.4l in 70 degrees and up?
- new engine
- ranger oil question???
- Yet another MAF question
- cel po442?????
- #1 and #2 Plugs
- oil on #1 cylinder plug, threads, tip
- Banks intake, catback?
- Overheating !!!!
- Mobil 1 in the 5 Qt.jugs...
- ??? for labnerd
- engine hiss
- P0153 Dtc
- Ok,Its not an F150 but how do you change the tranny oil and filter on a 2002 Explorer
- Throttle body fitting on 5.4L
- Engine Hesitating
- 100k+ and K & N
- Is this about right for my truck
- maf question
- Check engine light bulb change
- Dtc P0141
- no start???
- trouble codes p0171 & 0174
- Engine Missing, rough idle
- Oil analysis
- 97 5.4 to 99 5.4 power
- Need info on 88 F250
- Flex a lite fans and CFM required
- If you change your own oil, read some of these stories.
- Track Times for the 5.4
- Stalling out
- V6 4.2L Engine Blown?
- What's Next, Cheaper Mods???
- Mobil 1 0W-20
- Summit says the DON'T have part # for GY Belt?
- Odometer trick code list?
- Amsoil oil test results, test kit cost
- emissions experts??
- Steering noise
- Score your local DEALER Good/Bad Dealer Experience, Stories & Ratings
- Electric Cooling Fans Mod - Lincoln LS
- Corrosion? on DPFE sensor.
- oil change interval
- What the heck is this tube for?
- Pinging Fixed
- 4.6 towing
- E40D Tranny Problem
- F250 question
- 97 5.4 ticking
- high idle, HELP
