View Full Version : V8 Engines
- fuel system problems
- Reseting computer on 2k f150
- powerdyne supercharger on my truck
- new engine in....:):)
- Just wondering what you guys are getting for fuel mileage on the 4.6L 4X4's?
- 4.6 with low compression? HELP
- Outerwears Prefilters
- Need some help!
- Hey there
- want to change the plugs...or do I?
- Air Box Silencer Removed?????
- 17.09 @ 84.3, soon to get better
- '97 4.2L V6 Overheating; any suggestions?
- Major problem with K&N or HOAX!!!!!
- after cooler on a powerdyne supercharger...
- powerdyne supercharger ships today,
- oil drain plug
- syenthic oil
- Did I do the right thing? Bummed out!
- 4.6LV8F Earns "Highest Volume" title
- K&N Aircharger Kit vs. FIPF
- Synthetic convert
- Any custom ground cams yet.
- Short in Charging Circuit?
- Can anyone comment on this?
- Engine Torque Curves (4.6)
- What octane for a 5.4L V8???
- Spark Plugs and Wires
- question for WHAT RANGER
- Electric Cooling Fan or Stock Ctutch Fan?
- 1/4 mile times = 17.09 et
- Marvel Mystery Oil
- Fan Belt size
- spark plugs
- Dynos Don't Lie
- hooped out engine
- Jacobs or MSD ignitions
- KaN from a 97 4.6 to a 2000 5.4 exp.
- Engines
- dealer oil
- what is doh/oem
- vin decoder/nascar truck
- Powerdyne charger on, so is Check Engine light!
- INTERESTING ARTICLE ON OIL
- Gorp with the powerdyne supercharger
- Engine Tuning
- Problems All Over!!
- No Jacobs for 5.4...yet
- Pics of K&N FIPK Gen 2?
- 2 Rear Engine Seals in 30k km?
- Driving me bonkers
- mass air flow sensor
- My 4.6 just got stronger!
- Engine/Transmission mounts neutralization
- "ServiceEngineSoon" light blessing in disguise
- 4.6 Oil Consumption
- Knocking TSBs
- Piston Slap?
- Who has installed a supercharger?
- Take action, tell FRPP we wan't parts now!
- noise on startup
- NEW ENGINE IS IN!!!!!
- Where can I find a stock airbox for the 80mm MAF
- How can I make 400+ HP?
- Radiator Flush
- Fuel pump
- 2000 & MAF Sensors
- Headers?
- New engine noise
- tachometer
- Headers?
- Why we use 5w30 Hydrodynamic Lubrication
- Special Odemeter Readings???
- 99 5.4l rh cam shaft gear
- TSB Info on oil leak
- Ford Vehicle Identification Number Scheme
- Engine stumbling problems
- Special Feature On The Odometer...What Is It?
- Fuel Filter Replacement??
- Throttle Body Spacer????
- Check Engine light
- New Truck
- Where are the spark plugs?
- Pics of new engine as promised
- Jacobs Mileage Master or DIS
- Changed Antifreeze
- PENNZOIL????
- engine reving
- Can't get oil filter off
- Wide Throttle Body
- Superchip?
- Just 1000 miles and Smoke or condensation, that is the question!
- New Accel coil packs
- The best spark plug??
- belt tensioner pulley...
- Piston slap with synthetic oil?
- New Owner
- 5.4,V10, or Powerstroke
- 1999 F250 5.4L horsepower rating
- hidden feature in the odmeter
- Piston Slap Uncovered -- Measurements are...
- Finally Fixed the Rough Idle on my 4.6l
- 110 L/hr fuel pump for Powerdyne supercharger?
- What is our bore and stroke?
- 4.6 out of Police model Crown Victoria !!!
- Which filter?
- Engine Swap-New Lightning engine in my 4.64X4
- What is the HP rating on 99 4.6L
- 99 5.4 Rough Idle -- HELP!!
- Fuel Pressure Gauge????
- 82mph "chug" FINALLY solved for good.
- F150 eat's a valve!
- MOBIL1 OIL FILTER - BEST???
- Intake Manifold
- Fuel Check valve
- 4.9L engine stalling and Hesitating
- Fuel Pump keeps running
- Check Engine for no reason
- Is it worth replacing a slapper w/a FQR?
- What exactly is piston slap? How do you know if it's happening?
- K&N Filter question
- accel coil pack with jacobs dis
- Back again with Jacobs info
- Synthetic Oil Question
- 5.4 performance?
- blower ??
- Miles per gallon on Turbo Diesel/V10
- How can you tell rear gear ratio
- Starter Won't Quit
- SuperChip it?
- whats the difference between STX/SPORT
- '01 oil change - ford deserves an asswhipping
- She's in!!!!!!
- Problems w/ 4.6 slapper replacement
- 4.6L oil burning
- 4.6 or 5.4 need your input????
- Roush/Steeda adjustable timing devices
- Vacuum problems
- The Best Way To Get Blown For Under 2K
- My 4.6 is a weak engine
- 2001 F150 Finally to get 240hp 4.6!
- What is required in a pulley upgrade?
- Power-Mileage reeks of hog slop!
- Help me over at pickuptruck.com
- 5.4 Slapper
- Hey SS97FORD...
- Slapper Replacement
- Poweraid
- Recommended engine upgrades '97 Lariat 5.4
- Ok Time To Supercharge My 93 F-150, Need Advice And Answers!
- Email from Airaid regarding emissions.
- HELP - TOWING & OIL QUESTIONS!
- 4.2 / 4.6 / 5.4
- Question on "Check Engin Soon" Light
- what will a 4.6L run in 1/4
- 4.6L Specs, what's the difference?
- Ready to Hop-up!
- What is the best spark plugs?
- 2000 5.4 Dyno Numbers
- No start
- Increase in MPG for 2001 Supercrew
- Watch out for Oil Leaks!!!
- Is Airaid Emission Legal?
- 5.4 Liter Stats???
- Best Mods for 2000 5.4?
- Jacobs ignition works
- Vibration at 2000 RPM or 64 MPH
- Noise from engine ?
- Poweraid & Power Pulleys
- Need help on air intake
- Mustang MAF sensor?
- No EGR valve on 2000 6.8
- A/C compressor
- What kind of gas does everyone use?
- "Service Engine Soon" light
- Need some advice from you the experts.
- Fordfixer...help!
- Jacobs vs MSD ignition
- SPARK PLUGS ???????
- New engine "break-in"
- Airbox Mod Updates
- 2000 Triniton Horsepower Questions/Help!
- Detonation revisited....
- powerdyne s/c
- air force one cold vs pro-m 77
- Diagnostic codes
- Granatelli motor sports mass-air
- HELP! I'm going MAD!! (octane short bar)
- O2 sensor signal wire
- K&N? Looks different?
- Lots of carbon in new tail pipe
- Sudden rough idle, then it's gone!
- V6 Grow Up Plan.
- 302 to 429 swap
- Octane Shorting Bar
- Jacobs DIS ignition module.
- bosch plat 4 spark plugs
- super ford ????
- THERE ON ORDER
- Pro-M 77 MM MAF out does SuperChips
- To he!! with the V8, want this new engine
- Supercharger Questions
- EPA Mileage Ratings on Retail Sticker
- 5.4 oil cooler
- Airaid or Superchip???????
- V-10 Rattle From Top of Engine.
- FAN HELP!!!!!!!!
- what is detonation?
- please help
- new bosch plat 4 spark plugs
- Power Pulley Questions
- Ford, we have a problem, i think!
- Any fipk system pull cool air from fender well or a ram air type system?
- VIBRATION AT 65 MILES AN HOUR
- calling Y2K offroad
- airaid on it's way
- Vibration in Engine
- Engine Failure
- Timing chain prob. that sounds like piston slap??
- Chevy engines overhead cam?
- Supercharged finally
- 4 X 4 F--up
- Airaid or K & N FIPK?
- Any new FIPK systems on the horizone???
- 4.6 oil leak
- How many mile is to many to switch to synthetic?
- Supercharger/turbocharger
- K&N Filters
- Will Navigator or Cobra Heads fit?
- Does Piston Slap Get Worse with Miles?
- Synthetic Oil Benefit/Ask Nascar's #12 Team
- Ford Blues
- increasing horsepower 1994 F150 5.0
- is there a code reader available for our trucks?
- 4.2L tming cover recall
- intank fuel pump blues
- Oil Change Tricks
- gas mpg
- got dem dealer blues again!
- Breaking Spark Plugs
- help. need part number for tranny pan with drain plug
- Ignition upgrade questions.
- Help, Trouble Code 442 ???
- Gas Miliage
- Engine performance over time
- confused and need help
