fuel system problems
Old Jun 29, 2000 | 08:56 AM
taptones's Avatar
Question fuel system problems
My 87 F150 has an sudden rise in rpm between shifting (4spd). When I depress the clutch and remove my foot from the pedal, I experience a quick sudden rise in rpm as if I had hit the gas pedal, anyone have any clues?
Old Jun 29, 2000 | 10:41 AM
JMC's Avatar
JMC
25 Year Member
Post
Taptones,
Does it idle correctly? Check the throttle linkage for binding. Throttle position sensor could have a bad spot.
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
Borla Cat Back
Modified Air Cleaner Outlet Tube
and air box, K&N air filter,
Superchips
Old Jun 29, 2000 | 10:52 AM
taptones's Avatar
Post
Thanks, my truck idles fine when warmed up but when I firt start it, it dies then upon restart it will idle and then suddenly jump to a high idle for about 2 to 3 min. and then back down to normal. You may have hit the nail on the head! Thanks again!
