Jacobs vs MSD ignition
Old May 17, 2000 | 03:02 PM
32ndWave's Avatar
Question Jacobs vs MSD ignition
It seems that everyone who's upgraded their ignition has a Jacobs system. Are they better than the MSD's?
'99 XLT 5.4L 4x4ORP 3.73, White Supercab Flareside - Grill Guard, Superchip, Gibson cat-back, K&N FIPK
Old May 17, 2000 | 03:48 PM
Shawn75's Avatar
Cool
I use the MSD-5 ignition on my 96 truck. It is simply an enhancement to the stock ignition that gives multiple sparks instead of just one but only below 3600 rpm. The MSD-5 is inductive, not capacitive discharge like the really good ones but who needs that for a mostly stock engine? It only costs about $100 and installs quickly. My gas mileage went up by about 3 mpg and for all you tree huggers, my CO emissions went to zero after putting it on. I have noticed slight power gains with it on but not enough to say it is a "performance" upgrade. That's my experiences with the MSD ignitions, hopefully someone else will give their cut on the Jacobs models so you can choose for yourself.
Old May 17, 2000 | 09:08 PM
MI guy's Avatar
Thumbs up
I put a MSD into my old boat that had a Merc 350. Engine had over 700 hrs. of heavy load (full throttle is the only way to get there!). I was very impressed with the amount of improvement the MSD gave me. Engine ran smoother, much better throttle response, higher max RPM, gained about a 1/2 hour per tank (approx. 10%). This was an old and abused engine that had a lot to gain, a newer auto engine wouldn't see all this. I don't know about any of the specs or how the system works, but I wouldn't hesitate to buy another MSD.
Old May 17, 2000 | 09:52 PM
Pastmaster's Avatar
Post
I have a MSD 6A on my 1993 F-150 and I absolutely love it. I looked at a Jacobs Mileage Master system, but the price discouraged me from it. In all honesty, the Jacobs system probably is better.
Old May 17, 2000 | 10:26 PM
captainoblivious's Avatar
Post
Do any of the any the MSD ignition boxes work with DIS engines, besides the MSD DIS-4, which is only a little cheaper then the Jacobs. The MSD-5 ignition does sound a little better suited and more affordable for a near stock engine and daily driver, but will that one work with the later DIS engines?
black 97' x-cab 4x4, 5 speed 4.6, black westin nerf bars, 6 cd changer and a 12 premier sub, pilot ground searchers, borla SS split rear exhaust, v-tech oval side window covers
soon: fipk, chip, rims (the ones I want are $2k with tires, I need more money)
Old May 18, 2000 | 08:58 PM
WLF's Avatar
WLF
Exclamation
Msd does have a DIS Ignition but you have to cut into the electrical wireing on the 1997 and up engines (from what I could find out). I got the jacobs. Shop around as you have probably already seen in other message boards...
Black 1997 F-150 Supercab Flairside. 4.6L with Jocobs DIS, K&N Generation II, Cat back Exhaust (nice rumble). 17" Off Road wheel pkg. Lots of body mods. 4 yrs old and still turns heads...
Old May 18, 2000 | 10:40 PM
doorslammer69's Avatar
Post
just a reminder, folks, to call Summit at 1-800-230-3030 for a good price on Jacobs DIS box--abourt 50.00 less than MSD--you MUST use a DIS box on 97 & up--can't use others.
Old May 19, 2000 | 10:34 PM
WLF's Avatar
WLF
Exclamation
Haven't forgot you doorslammer. Can't seem to find where I put the paperwork on the Jacobs. Only one place left to look. I'm going there tomorrow. I'll fax it then...
