engine reving
Old Jun 5, 2000 | 02:33 PM
mel's Avatar
mel
Question engine reving
i have a 99-V6, manual transmission....when i take it out of gear to slow down, my foot off the clutch...just on the brake...the engine will rev on its own. If i tap the excelerator, it does not stop the engine from reving. i have had it back to the dealer once...and they say nothing is wrong but it continues to happen. can anyone help me or tell me what might be wrong???
thank you!!
ps
i also posted this in the V6 area...was not sure where it best fit!!
99' Black F150 ext-cab
V6-Manual 4x2
Mods:
Tinted Windows
Awia CD Player
Pioneer Spkrs
Flowmaster Exhaust
Rear exit/18" Chrome Tips
K&N Filter
Stainless Steel Nerf Bars
BFG A/T 265/75R/16's
Old Jun 5, 2000 | 02:39 PM
JMC's Avatar
JMC
25 Year Member
Post
Mel,
How high an RPM does it rev to? Does it do the same thing when you are stopped or only when the truck is moving?
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
Borla Cat Back
Modified Air Cleaner Outlet Tube
and air box, K&N air filter,
Superchips
Old Jun 5, 2000 | 03:22 PM
mel's Avatar
mel
Post
JMC,
once i come to a complete stop it seems to come back down to normal. as far as how high it revs....i do not have an indicator for RPM's but it sounds pretty loud...it is like going 25-30 MPH in first gear. thanks for any suggestions...
mel
Old Jun 6, 2000 | 01:51 PM
Bones's Avatar
Post
Well this isn't nearly the same as mine but when I'm driving, if i take my truck and put it in nuetral while rolling down a hill (just to see how fast it would get going) then my engine will pick up RPM's. mine will jump 1k RPM's.
Even when your coming to a stop don't put it nuetral. Use the engine to help you brake. Put it in the next gear down and let off the clutch. It will help you slow down and prolong the life of your brakes.
Bones
2000 F-150, XLT, 4X2, Ext. Cab, S/B, 4.6L, 3.55 L/S, Tow Package, Sony CDX-C7050X Head Unit, 6.5' Sony Three Way Speakers In Each Door. Hopefully An Amp And 12' Sub Soon.
Future Mods: NONE, I'm broke.
Old Jun 6, 2000 | 05:46 PM
mel's Avatar
mel
Post
Bones,
thank you for your response....i will try what you are talking about and see if it helps...but i will say it does happen consistantly. Like it has not happened at all today but yesterday it did it all the way home. it is kind of frustrating.
thanks again,
mel
Old Jun 8, 2000 | 03:01 AM
dragonboy's Avatar
Post
I had this same problem with the ranger I had, and I found out the floor mat will get stuck with the gas pedal it happened all the time so I change the floor mats. just my .02 pennies
2000 F-150, S/C F/S 5.4lt Auto, 3.55 LS, M4x4, Capt. Chairs 6 way elec., 6 CD, etc,etc,.
Med Toreador Red
Born 03-27-00
Mods,
Superchip UAT2
Borla Anniversary Edition Split rear cat back
K&N Gen II or FIPK
Granattely Mass Air Flow
SVT Lightning 18" wheels
285/60/18 Pirelli scorpion Zero
Hellwig Sway bar
Dark Walnut dash kit
Muth signal mirrors
White face gauge
Bosch Plat. 4's
Retrax Rolltop
Outland sport bumper guard
Rancho rsx shocks
Lund Front Runner
Underhood sound insulation panel
Piaa Plat. super white Bulbs
Catch All floor mats
Lund Back Draft tailgate spoiler
Old Jun 8, 2000 | 07:23 AM
msparks's Avatar
Post
I have a 97 4.6 manual. It does the same thing. The revs will stay up around 1300 RPMs or so, then after a few seconds will come back down to idle. I really haven't given it much thought. I figure it must be something to do with the air conditioner or the heat. I don't know. Mine is out of warranty now so I don't think I will be taking it in.
If you happen to figure out what is causing this rev thing, please let me know.
BTW I have a K&N filter on it!
Lube-Direct
New Lubrication Forums
Old Jun 8, 2000 | 10:21 AM
Indyfan's Avatar
Post
OK, here goes a wild-*** guess. I've noticed some Japanese cars do the same thing and I've developed a theory. I believe the computer keeps the RPMs high to make shifting easier (or smoother). It's the equivalent of goosing the gas a little before letting out the clutch.
That's my .02 worth.
1999 Lariat Super Cab, S.B. 5.4L, 3.55 LS
and everything but the leaky slider window.
Bright red w/ gold 2-tone, Leather Captain's Chairs
Mods: Duraliner bedliner, Bugflector II, Hide-a-hooks.
& a leeetle chrome tip on the exhaust.
Old Jun 8, 2000 | 11:12 PM
DarnEFNET's Avatar
Post
actually this is very common, go drive a taurus and put it in nuetral on the highway, it will stay around 2500rpm. It is done for emission purposes
Old Jun 9, 2000 | 09:38 AM
mel's Avatar
mel
Post
i understand what you all are saying....but this problem just started happening about 3 weeks ago...the first 17,000 it did not happen at all. that is why i think something has happened or something is wrong. do you agree???
Old Jun 9, 2000 | 10:01 PM
wake's Avatar
Post
This is a common issue with emission controls. Evidently abruptly taking your foot off the gas increases emissions. If this just started, I suspect some "dirty" burn from bad gas, clogged air filter, bad plugs, etc. There may also be a faulty sensor somewhere. There could also be a programmed rpm or mph threshold under which it won't happen - try waiting to push the clutch in until the rpms are around 1000 and see if it acts normally.
IMHO, its always good practice to keep it in gear anyway to maintain control over the truck. You can downshift without burning the clutch by briefly stabbing the throttle to match the revs.
Old Jun 16, 2000 | 02:17 PM
JMC's Avatar
JMC
25 Year Member
Post
mel,
Glad to hear you got it fixed. Mine stays at about 1000 rpm when I clutch in at speed and that is normal. I wish it would drop to idle but you can't have everything.
Regards
Jean Marc Chartier
Borla Cat Back
Superchips
Old Jun 16, 2000 | 03:07 PM
f150nvball's Avatar
Post
I have 97 4.6 5 speed 2x4. When I push the clutch in rev. stay at 1000 rpm but if I hold clutch in for a few seconds the rpm drops to 600 idle speed. Tehn if I take my foot off the clutch the rpms stay at 600 and I can coast at that engine rpm till I put it back in gear.
Old Jun 17, 2000 | 12:37 AM
mel's Avatar
mel
Thumbs up
thanks for all of the responses. i just wanted to say that the problem was solved. i went back to the dealership when it was acting up and had the service manager ride with me. after he witnessed it first hand, then he took it back....it was a throttle position sensor. problem solved!! yea!!
[This message has been edited by mel (edited 06-16-2000).]
