Roush/Steeda adjustable timing devices
Old May 28, 2000 | 11:33 AM
doorslammer69's Avatar
Post Roush/Steeda adjustable timing devices
Both Roush & Steeda offer bolt-on adjustable timing devices for the 4.6. Is anyone using it, or has anyone tried My e-mail account is down right now, so please e-mail me at SundayNiagara@hotmail.com....Thanks, my truck is listed elsewhere under engines.
Old May 30, 2000 | 11:09 AM
JMC's Avatar
JMC
25 Year Member
Post
DS 69,
I called Steeda and they said you need about 2" of clearance in front of the crankshaft damper for this to work. You bolt this timing wheel on to the damper. Then
you remove the timing sensor and bolt the adjustable sensor holder to that. The sensor then attaches to the holder and takes its reading from the outside wheel. You are now able to adjust your timing. You have to move the A/C compressor out of the way to install. It is not a mechanical advance but electric so you won't push any valves into the pistons. Try one and let the rest of us know how (if) it works.
regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
Borla Cat Back
Modified Air Cleaner Outlet Tube
and air box, K&N air filter,
Superchips
[This message has been edited by JMC (edited 05-30-2000).]
Old May 30, 2000 | 01:45 PM
Post
Thanks for your reply on this issue JMC. However, I'm not looking to be the guinea pig on this one & would prefer to hear from someone who already has it installed--ds69
