View Full Version : V8 Engines
- Noisy Lifter?
- Spark Plug Trouble, Need Help Quick!
- LEMON LAW
- Any Oil Press/Water Temp Readings
- Check Engine Light
- K&N FIPK on sale @ truckperformance.com
- K&N FIPK: how often should filter be cleaned & oiled?
- Need 180 degree thermostat info
- 5.4L Oil Pressure/Water Temp
- Air box mods/Hood scoops
- Need some help??
- need advise on SuperCharger kits
- Fuel Line Disconnect Tool (where to buy)
- Motorcraft filters at auto parts store are factory 2nds?
- Dealer Questions Pulley
- Torque help
- Replacing a Tappet --- Need Advice
- Maybe it wasn't the Powerdyne after all!!
- WHAT F-150 for HIGH ALTITUDE should i buy
- Service says "no" to synthetics and torsion bar cranking.
- WIRES!!
- 5.4L Spark Plug Change
- Plugs?,Wires?
- Camshaft Sensor
- swap engine to diesel?
- Benefit to resetting computer
- f150freak
- Engine RPM's at Various Speeds
- Outran a 6.0 Liter Chevy
- Spark Plugs
- f150freak maf senser
- Header Exhaust Leak, I Think, Need Help
- Platinum Plugs
- Spark plug
- Tornado
- New Thermostat??
- what is the horsepoewer for a 89, 302
- NO2 PRO/CON?
- oil smell
- WIRES
- f150freak s.o.s.
- Help with my Stock chip/computer?
- Ford 300 i-6's
- Ticking / Knocking Sound...
- new or fqr on 99's?
- Need help witha couple questions here
- Synthetic oil plans-Any Suggestions?
- Ford Higher Up Problems
- Changing Coolant
- air filters
- Total Engine Shutdown – Help!
- Miss fire on 5.4 usually when damp. Please help.
- Bought my bosch +4's
- granatelli or shm mass air flow sensor ?
- Lightning chip in a 351W?
- Order your TSB's
- 4.6L Detonation sound??
- Power loss w/ larger tire sizes? How bad?
- looked at 99 lightning
- Engine flush
- "BIGGER" Throttle Body or Spacer????
- Mobile1 Users - "Special Value"
- Sound Ford Renton Washington
- Heat Sensor Problem?
- Power Pulley??!!! What's the deal with these??
- Arching plug wires
- Timing?
- Wix filters
- Valve Rattle Cured
- 2000 RPM in Neutral
- speed limiter
- dangerously high idle...sometimes
- clutch fan
- Again with the oil questions.
- Symptoms: Whistling noise and rough idle when truck is really hot!
- Carburator problem?
- B & M SHIFT PLUS
- 2000th topic!!!
- Has anyone towed with a 98 Nascar Edition
- CALLING ALL AMSOIL USERS!
- ORP..new truck
- 1990 fuel pump?? Are engine schematics available???
- tornado and efi
- Error code reader?
- check oil light
- What's an STX?
- PowerAid on V10
- My .02 on open air box FIPK's
- oxygen sensor
- burning oil
- Top Three Mods
- K&N
- Do ya'll think I can outrun a 4x4OffroadSeries Dodge Ram
- PowerAid WO/FIPK on a 5.4???
- Weak straight six
- Stalling at idle in drive?
- Taking the slack outta the "go pedal"? ; )
- first time ford owner
- Change the spark plugs on my 97'??
- F150xl 5.4, reg. cab, SWB, 4x2, weighs 4140, Track times
- In need of a FORD Tech to solve problem!!!
- Are All 4.6 V-8's Tritons???????
- POOR g-Tech readings..Please help...
- Anyone with aftermarket headers on their F150?
- Would the 7.3 PSD fit in a 97+ 150?
- Doggy because of the heat???
- Oil filter help
- Used Truck
- Carbon buildup iinside TB & manifold
- Need Help w/ Airaid
- Radiator swap
- the most fun...
- Are there any REAL products proven to improve mileage out there?
- Ford -VS- Pontiac...cold engine noise!!!
- Air Box Modified
- Ford V-10 engine performance
- Top Ten Engines Website
- Oil Additive
- Lightning Supercharger
- roaring F150
- V6 rough during Accel and at Cruise Speed
- Magnacharger Dyno Numbers
- I can make my engine shut off backing up a hill...can you?
- K&N Filter Installed, Reset Computer?
- '92 F-150 stutters only when cruising
- mustang compatible parts?
- How many O2 sensors on a '96 F-150, 5.0L?
- I need HELP!!!!!
- MAF question
- Question?
- Internal Engine Diagnosis
- Airbox mods. + Exhaust mods. = "Service Engine Soon"?
- Start-up noise on 4.6
- HUMMING NOISE
- CLEARING THE COMPUTER
- The ULTIMATE "cold" airbox mod. CHEAP!!!
- What do YOU think Ford will do?
- Most reasonable HP gain?
- Help me find
- Another, possibly silly, airbox mod question..
- k&n question
- 5.4 "piston slap" date survey???
- 2001 4.6L 20 H.P. Boost?
- Spark Plugs???
- stalling when hot
- 4.7L Dodge engine vs. 4.6L Ford
- 4.10 or 4.30 Gears??? + Protorque Converter
- Just wonderin
- brotherdave
- PISTON SLAP WOW!!!
- 85 f150 don't start
- Please Help Me Choose Next Performance Upgrade!!!
- Cold-start problem
- WMS Velocity Tube?
- Looking for spec's on 5.4L 1999 Triton
- 5W-30 vs 10W-30
- LEV trucks?
- Spark plug replacement on 5.4 engines
- Superchaged Engine
- Can I get more power out of an inline six?
- oil change
- COLD/HOT INTAKE AIR SCIENTIFIC PROOF
- 4.6 Stroker Kits
- ford man 3
- when to change plugs??
- Jacobs wires only or DIS?
- any tips for high altitude operation?
- Flickering Check Engine Light - any suggestions?
- Octane Booster. WOW!!!
- A/C compressor noise
- Belt noise - cold mornings
- 99 - 5.4 Engine Noise
- 5.4l vs 5.3l
- 4.6l vs 4.8l
- Is it ok not to use a different thermostat with hypertech chip?
- top end coughing
- Engine coolant
- Anyone us a scan tool
- LOSE YOUR FAN ROAR WITH A SHIFTPLUS!!
- Truckperformance.com su&ks
- Best exhaust setup
- WHERE/HOW TO GET OIL ANALYSIS???
- Gas Milage
- Power Aid TBI Spacer
- 1999 5.4 Plug coil failure, stumbling idle and service bulletin
- Which air intake mod is the best?
- new member
- Which engine best for me?
- What to do first?
- Troubled F 150/help please
- Smokin' Blue
- Oil Pan Heater Kits
- Oil Pressure Loss (Engine will not start)
- 95 F150 V8 - Oil Leak?
- Here are the numbers!!
- What should I trade my Powerdyne for?
- WHO WANTS TO BUY CHEAPER GAS???? ITS RIGHT NEXT TO YOUR HOUSE!
- Airraid air dam for Lightning fit our trucks?
- Can I get a new engine?
- Added Horsepower?
- K&N FIPK gen II ?
- What's the latest on piston slap?
- Poweraid
- 9 psi on my powerdyne.
- Airaid
- Any detonation problems with superchips?
- When can I switch to synthetics?
- K&N or Airaid?
- Wanna lay some whoopass on a Lightning?
- refrigerated intercooler.
- 160 Degree Thermostat?
- best replacement spark plugs?
- What are the affects of warm air into the motor?
- Life expectancy after engine mods
- Porting aluminium question??
- Airbox Modifications: My thoughts & your opinions.
- fuel pressure drop
- THE "FREAK" needs some help?
- rough idle and now engine light is on.
- SPARK PLUG REMOVAL ON 5.4?
- What spark plugs to use w/ Supercharger?
- A woman at the service department said...
- Help! MIL - P0401 EGR valve insufficient flow
- RPM
- RPM Limiters In New Ford F150s?????
- Supercharger???
- engine treatments
- Supercharger Boost Presure
- NOS vs Superchargers
- rpm power band?
- K&N oil filters?
- Synthetic Oil Pole
- Help for pinging?
- 300
- hey dragonboy !!
- Oil for F150 Supercrew 2001
- Tell me how much it costs
- Hypertech detonation problem
- Blown Head Gasket?!?!?!
- K&N-worse gas mileage??
- HP guesses anyone??
- NOS anyone?
- Whats the dif. between K&N FIPK, volicity tube, etc.?
- Spark Plugs
- Att: Dirt Bike Dave!!!!!!!!!!!!!!!!!!!!!!
- Ignition suggestions....
- Hole in my gas tank
